VS X8 Ultimate
System:
W10 64-bit
ASUS Z97-AR Rev 1.xx mother board
Quadcore i7-4790K running hyperthreaded (8 virtual cores)
Intel(R) HD Graphics 4600
16 GB DDR3
4 TB hard drive.
VS Project settings
"Edit->Project Properties" settings:
Mobile
MPEG-4 Files
24 bits, 1920 x 1080, 29.97 fps
Frame-based
H.264 High Profile Video: 5000 Kbps, 16:9
48000 Hz, 16 Bit, Stereo
MPEG AAC Audio: 256 Kbps
"Share->Computer->Custom" settings:
MPEG-4 Files
Frame-based
"Share->Disc->DVD" Settings
MPEG files
24 bits, 720 x 480, 29.97 fps
Upper Field First
(DVD-NTSC), 16:9
Video data rate: 8000 kbps
LPCM Audio, 48000 Hz, Stereo
The mp4 file comes out beautifully.
No moire effect, no jitters.
However, the DVD iso file is jittery and shows Moire effect, where the mp4 file does not.
The jitters in the DVD iso file are in the same place every time its played.
When a DVD is burned from the iso, the jitters appear in the same places, as well as the Moire effect.
Any suggestion?
Seeing some jitter on DVD but not on mp4
tcamuso
- motherboard: ASUSTeK D700SA
- processor: 2900 MHz Intel Core i7-10700
- ram: 48 G
- Video Card: IntelR HD Graphics 4600
- Hard_Drive_Capacity: 2 TB NVMe
- Monitor/Display Make & Model: DELL ST2421L
- Corel programs: Video Studio 2021 Ultimate
Re: Seeing some jitter on DVD but not on mp4
Why did you change from Frame based to Upper Field first - - changing frame order can cause the problems your describing
tcamuso
- ram: 48 G
Thank you for responding!BrianCee wrote:Why did you change from Frame based to Upper Field first - - changing frame order can cause the problems your describing
I didn't change it. That was the default setting.
What is the recommended setting for this option?
You should try where possible to use the same frame order as your original video file, Frame Based.
Some options…
1 / You could convert the good Mpeg4 file to Mpeg2 then use that to burn a DVD (settings as below)
2 / Change the DVD burn settings as below.
3 / Set the Project properties to use – as below - then the burner will use same settings.
MPEG files
Frame-based
(DVD-NTSC), 16:9
Video data rate: 8000 kbps (constant)
Audio data rate: 256 kbps
Either way downscaling 1920 to 720 is gonna impact on quality.
You could create a video to play on TV via USB memory stick, that way you could retain 1920 x 1080.
Oh before rendering again -- go to Preferences – Edit tab – resample to Best
Some options…
MPEG files
Frame-based
(DVD-NTSC), 16:9
tcamuso
- ram: 48 G
Many thanks, Lata, for the suggestions!
I've been to this board many times and have ALWAYS found answers to my questions. One of the most responsive boards on the internet!
