4GB filesize limit with XAVC-S
Re: 4GB filesize limit with XAVC-S
Hi Andre
I have also tested X8 and get the same error messages.
Have you had a reply from Corel?
erdna
motherboard: Gigsbyte H81M
processor: I7 4770
ram: 16GB DDR3
Video Card: Intel HD4600
sound_card: Intel display audio
Hard_Drive_Capacity: 1TB 7200rp
Monitor/Display Make & Model: Panasonic TX32cx600e
Post by erdna »
Hereunder the only message I got (yesterday)
##- Please type your reply above this line -##
Ticket (3607849) has been created for you. If you created the ticket through one of our forms it will be reviewed by one of our customer support agents as quickly as possible.
If you would like to add something to this ticket just reply to this email. Your emails will be added to the ticket.
Andre Declercq
Apr 26, 06:41
I want to create a 10 min XAVC-S UHD novie in Corel VSX9 (output setting: XAVC-S 3840x2160 25p @65Mbps). Did not work...all went well untill the end of the render process (99%) where I got the "file format mismatch" prompt, A file was created with rhe expected (>4GB)size but does not play.
My UHD clips come from a Sony FDRAX33 UHD camcorder @100Mbps framerate setting
I found out that when the total rendered filesize is below 4 GB all goess fine. The original clip are stored om an NTSF formatted disk as well as the target disk is NTFS. The same problem happens with HD originals when trying tp get an UHD XAVC-S output larger than 4GB (~9 min @65 Mbps).
There is also a thread in the Corel User to User forum where the problem has been confirmed . See http://forum.corel.com/EN/viewtopic.php?f=1&t=59251
Visit the Knowledge Base and search through our extensive selection of articles
Looking for inspiration for your next project? Visit the Discovery Center for great tutorials and project ideas.
Hi Andre
if one of your original recordings is greater than 4 Gb does that import to VS and play ok.?
erdna
processor: I7 4770
ram: 16GB DDR3
Post by erdna »
Hi Trevor ,
I will try an original >4GB file tonight and report tomorrow. F.Y.I. still black-out from the Corel Support side.
Andre
canuck
operating_system: Windows 8.1
Post by canuck »
I don't think your source file or its size has anything to to with the 4GB limit when creating the "Xavs" file. I did a quick test by creating 2 Xavs files (with the properties that erdna showed in his first post". As a source I used a simple mp4 file that was about 4 minutes long. I added that file 3 times and then trimmed it back so that it was just a bit over 10 minutes long. When rendered it created a 4.08 GB file that will not play with any player. In fact MediaInfo is not even able to determine the properties. I then used the same setup and trimmed it to be under 10 minutes. The rendered Xavs file was now around 3.9GB and played fine in all video players and BS also accepted it.
canuck wrote:I don't think your source file or its size has anything to to with the 4GB limit when creating the "Xavs" file. I did a quick test by creating 2 Xavs files (with the properties that erdna showed in his first post". As a source I used a simple mp4 file that was about 4 minutes long. I added that file 3 times and then trimmed it back so that it was just a bit over 10 minutes long. When rendered it created a 4.08 GB file that will not play with any player. In fact MediaInfo is not even able to determine the properties. I then used the same setup and trimmed it to be under 10 minutes. The rendered Xavs file was now around 3.9GB and played fine in all video players and BS also accepted it.
I was interested to know if original video over 4 Gb ran ok, and that the problem was only with video rendered with Video Studio.
I assume it is the way Video Studio is rendering that's causing the problem.
For me rendering is very, very slow, maybe my pc but also suspect VS is struggling with this format.
Like you MediaInfo does not read the file correctly, windows shows the icon as audio type when I would expect a video type.
Certainly needs Corel to look into this issue.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
Since its always run smoothly till the 99% checkpoint , I believe it's a matter of finalizing the file to conform with the Xavc profile itself and not the video rendering per se.
** Trevor ~10min here took ~66min. Not much of a Derby favorite...
Panasonic X900m, VXF1
erdna
processor: I7 4770
ram: 16GB DDR3
Post by erdna »
Hi Trevor,
Same story with an original 6GB file; "File format mismatch" and a useles ~6GB XAVC output file.(the original 6GB file imports OK)
Got an answer from Corel...general and worthless. See hereunder with my reply
Van: Corel Customer Support [mailto:mycasesupport@corel.com]
Verzonden: Friday, April 29, 2016 11:03
Aan: Andre Declercq
Onderwerp: [Corel] Re: 4GB (3.7 GiB) XAVC-S rendered file size limit.
There is not a single corrupted clip involved (all verified). More people tested and confirmed this issue. Plse see the User to User forum link I gave below and/or test it yourself. Point is that VSX9 (and X8) cannot create XAVC-S video’s that are larger than 4GB
Your request (3607849) has been updated. To add additional comments, reply to this email.
Kaz Brual (Corel)
Apr 29, 05:02
Andre Declercq,
Thank you for contacting Corel Technical Support.
We appreciate your time in letting us know your status with your product and we understand where you are coming from. As I am reviewing your concern, I would like to inform you that there might be a corrupted video clip in your project that causes failure to import, edit, render or burn.
What I would like to suggest is for you to do a test render for each video clip that you have used in your project. This is to determine which video clip is corrupted. Then just delete that particular clip or if you need it, convert that video clip into another format or re-convert it to the same format to fix it.
Please do not hesitate to contact us with any further questions.
Kaz
Corel Technical Support Services
Hi Andre
Thanks for the update, If your original file at 6 Gb is causing problems then its VS not reading the files correctly, so maybe not just the render issue but any 4K greater than 4 Gb.
I can understand Corel suggesting there may be a corrupt file, but the quickest option for them is to try to replicate the problem, and that is easily done.
They could use any clips provided the project is over 10 minutes would exceed 4 Gb and would fail.
That’s assuming there support have the capability or ability of testing 4K files.
Unfortunately I doubt that support will read this topic.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Trevor, Andre write that the 6GB file was loaded OK to X9.
Don't blame the poor Corel guy, he works with a help line error flow chart diagram. I don't see this as a difficult thing to mend, SP4 might do it.
( I shoot in the dark trying to correct my 4.7GB file , but it didn't work...)
erdna
processor: I7 4770
ram: 16GB DDR3
Post by erdna »
Hi Trevor and asik,
I think I already mentioned it, but HD files (1920x1080) on the rimeline give the same results when rendered as XAVC-S
Andre
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
erdna wrote:Hi Trevor and asik,
Andre
Because it has nothing to do with the input files , I believe if you will render 1 JPG file to 10min XAVC-s you will get same bad output.
If you bored for few minutes you can see VLC error report trying to play the file
(I'm far of being an expert but I think the problem lay in the "no moov box" and EOF in these >4GB files )
core debug: processing request item: X9.mp4, node: Playlist, skip: 0
core debug: resyncing on X9.mp4
core debug: X9.mp4 is at 0
core debug: starting playback of the new playlist item
core debug: creating new input thread
core debug: Creating an input for 'X9.mp4'
core debug: requesting art for X9.mp4
core debug: using timeshift granularity of 50 MiB, in path 'C:\Users\AppData\Local\Temp'
core debug: `file:///C:/out/X9.mp4' gives access `file' demux `' path `/C:/out/X9.mp4'
core debug: specified demux `any'
core debug: creating demux: access='file' demux='any' location='/C:/out/X9.mp4' file='C:\out\X9.mp4'
core debug: looking for access_demux module matching "file": 12 candidates
core debug: looking for meta fetcher module matching "any": 1 candidates
lua debug: Trying Lua scripts in C:\Users\AppData\Roaming\vlc\lua\meta\fetcher
core debug: no access_demux modules matched
lua debug: Trying Lua scripts in C:\VLCPortable 2.2.2\App\vlc\lua\meta\fetcher
core debug: creating access 'file' location='/C:/out/X9.mp4', path='C:\out\X9.mp4'
core debug: looking for access module matching "file": 21 candidates
filesystem debug: opening file `C:\out\X9.mp4'
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\meta\fetcher\tvrage.luac
core debug: using access module "filesystem"
core debug: Using stream method for AStream*
core debug: starting pre-buffering
core debug: received first data after 0 ms
core debug: pre-buffering done 1024 bytes in 0s - 1000000 KiB/s
core debug: looking for stream_filter module matching "any": 6 candidates
core debug: no stream_filter modules matched
core debug: looking for stream_filter module matching "record": 6 candidates
core debug: using stream_filter module "record"
core debug: looking for demux module matching "mp4": 66 candidates
mp4 warning: Unknown uuid type box
mp4 debug: found an empty box (null size)
ts debug: TS module discarded (lost sync)
mod debug: MOD validation failed (ext=mp4)
lua debug: skipping script (unmatched scope) C:\VLCPortable 2.2.2\App\vlc\lua\meta\fetcher\tvrage.luac
core debug: no meta fetcher modules matched
core debug: searching art for X9.mp4
avcodec debug: trying url: C:\out\X9.mp4
avcodec debug: CPU flags: 0x010053db
core debug: looking for art finder module matching "any": 2 candidates
avcodec debug: detected format: mov,mp4,m4a,3gp,3g2,mj2
avcodec debug: Trying to seek too far : EOF?
avcodec error: Could not open C:\out\X9.mp4: Unknown error
lua debug: Trying Lua scripts in C:\Users\AppData\Roaming\vlc\lua\playlist
lua debug: Trying Lua scripts in C:\VLCPortable 2.2.2\App\vlc\lua\playlist
lua debug: Trying Lua scripts in C:\Users\AppData\Roaming\vlc\lua\meta\art
lua debug: Trying Lua scripts in C:\VLCPortable 2.2.2\App\vlc\lua\meta\art
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\anevia_streams.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\meta\art\00_musicbrainz.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\anevia_xml.luac
lua debug: skipping script (unmatched scope) C:\VLCPortable 2.2.2\App\vlc\lua\meta\art\00_musicbrainz.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\meta\art\01_googleimage.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\appletrailers.luac
lua debug: skipping script (unmatched scope) C:\VLCPortable 2.2.2\App\vlc\lua\meta\art\01_googleimage.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\meta\art\02_frenchtv.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\bbc_co_uk.luac
lua debug: skipping script (unmatched scope) C:\VLCPortable 2.2.2\App\vlc\lua\meta\art\02_frenchtv.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\meta\art\03_lastfm.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\break.luac
qt4 debug: IM: Setting an input
lua debug: skipping script (unmatched scope) C:\VLCPortable 2.2.2\App\vlc\lua\meta\art\03_lastfm.luac
core debug: no art finder modules matched
core debug: art not found for X9.mp4
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\canalplus.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\cue.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\dailymotion.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\extreme.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\france2.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\googlevideo.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\jamendo.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\joox.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\katsomo.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\koreus.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\lelombrik.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\liveleak.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\metacafe.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\metachannels.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\mpora.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\pinkbike.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\pluzz.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\rockbox_fm_presets.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\soundcloud.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\vimeo.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\youtube.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\youtube_homepage.luac
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\playlist\zapiks.luac
ps warning: this does not look like an MPEG PS stream, continuing anyway
core debug: using demux module "ps"
core debug: looking for a subtitle file in C:\out\
core debug: looking for meta reader module matching "any": 2 candidates
lua debug: Trying Lua scripts in C:\Users\AppData\Roaming\vlc\lua\meta\reader
lua debug: Trying Lua scripts in C:\VLCPortable 2.2.2\App\vlc\lua\meta\reader
lua debug: Trying Lua playlist script C:\VLCPortable 2.2.2\App\vlc\lua\meta\reader\filename.luac
core debug: no meta reader modules matched
core debug: `file:///C:/out/X9.mp4' successfully opened
ps warning: garbage at input, trying to resync...
ps warning: found sync code
ps debug: we found a length of: 7596s
ps debug: we found a length of: 45857s
ps debug: we found a length of: 72142s
core debug: selecting program id=0
core debug: looking for decoder module matching "any": 43 candidates
core debug: using decoder module "mpeg_audio"
mpeg_audio debug: emulated startcode (no startcode on following frame)
ps debug: es id=0xfa format unknown
mpeg_audio debug: free bitrate mode
avcodec debug: trying to use direct rendering
avcodec debug: allowing 4 thread(s) for decoding
avcodec debug: avcodec codec (MPEG-1/2 Video) started
core debug: using decoder module "avcodec"
core debug: looking for packetizer module matching "any": 23 candidates
core debug: using packetizer module "packetizer_mpegvideo"
packetizer_mpegvideo debug: waiting for sequence start
ps debug: es id=0xf8 format unknown
core debug: Buffering 0%
ps debug: es id=0xf7 format unknown
ps debug: es id=0xfe format unknown
ps debug: contains a PSM
ps debug: es id=0xf5 format unknown
avcodec debug: avcodec codec (H264 - MPEG-4 AVC (part 10)) started
avcodec debug: using frame thread mode with 4 threads
core debug: using packetizer module "packetizer_h264"
ps debug: es id=0xfc format unknown
ps debug: es id=0xf3 format unknown
mpeg_audio debug: frame too big 2883 > 2882 (emulated startcode ?)
ps debug: es id=0xff format unknown
core debug: EOF reached
core debug: Stream buffering done (-723 ms in 1253 ms)
core debug: Decoder wait done in 0 ms
core debug: finished input
core debug: removing module "mpeg_audio"
core debug: killing decoder fourcc `mpga', 0 PES in FIFO
core debug: removing module "avcodec"
avcodec debug: ffmpeg codec (MPEG-1/2 Video) stopped
core debug: killing decoder fourcc `mpgv', 0 PES in FIFO
core debug: removing module "packetizer_mpegvideo"
avcodec debug: ffmpeg codec (H264 - MPEG-4 AVC (part 10)) stopped
core debug: killing decoder fourcc `h264', 0 PES in FIFO
core debug: removing module "packetizer_h264"
core debug: removing module "ps"
core debug: Program doesn't contain anymore ES
core debug: removing module "record"
core debug: removing module "filesystem"
core debug: dead input
core debug: changing item without a request (current 0/1)
core debug: nothing to play
qt4 debug: IM: Deleting the input
erdna
processor: I7 4770
ram: 16GB DDR3
Post by erdna »
The log seems to tell us that several steps go wrong, but I think that we would rather need the XAVC encoder source code to get closer to the problem.
I also tested a 10 mn extented jpeg rendered @65Mbps XAVC and again "File format mismatch" at 99%. And btw (and totally off topic), I would not advise X8/9 for jpeg work in UHD (e.g. UHD slideshow ). As you may recall I reported seversl months ago that there is a resolution issue. In the link hereunder I compared 2 (Corel X8 and Somy) UHD 1:1 pixel mapped crops from UHD video's made from jpeg's (ISO test pattern)
https://www.dropbox.com/s/huiit13txir5s ... s.jpg?dl=0
Hi Asik
Andre confirmed earlier that an original video direct from camera at 6 Gb causes the same error when importing to library.
So clearly it is not just the rendering but the way these files are read.
Asik I don’t blame the Corel guy but Corel for not giving him the correct tools to test this problem.
Corel need to try to replicate the problem, Andre already provided a link to his post on the forum, so why do Corel recommend he asks here? Clearly Corel Support has not visited or read this post.
SP4 wont do anything unless Corel can replicate the problem, and that wont happen till the issue is escalated to their engineering depot.
erdna
processor: I7 4770
ram: 16GB DDR3
Post by erdna »
Hi Trevor,
You wrote: " Andre confirmed earlier that an original video direct from camera at 6 Gb causes the same error when importing to library.
I think I reported that my origina 6GB clip imported OK. So I got the original clip to the library and to the timeline, but the rendering went wrong again at 99%.
Andre
