gstreamer0.10 dependency problem
gpe
- System_Drive: N/A
- motherboard: ASUS P8P67 LE
- processor: i5-2500k
- ram: 16 GB
- Video Card: Nvidia GTX550Ti
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: Dell U2410
- Corel programs: AfterShot Pro 2
The new linux distributions don't have gstreamer0.10 anymore.
Thanks to make AfterShot compliant with gstreamer1.0.
dFlyer
- System_Drive: N/A
Re: gstreamer0.10 dependency problem
If your running Ubuntu 16.04 LTS please see this link:
http://forum.corel.com/EN/viewtopic.php?f=90&t=59077
both required files are in the repositories.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
gpe
- System_Drive: N/A
- ram: 16 GB
No, I'm using Debian testing. Gstreamer0.10 has been removed form the repositories. So the next Debian stable (Debian Stretch) will not have Gstreamer0.10.
- urlisse
- System_Drive: N/A
- motherboard: ASRock AM1H-ITX
- processor: AMD Athlon 5350
- ram: 4GB
- Video Card: Integrated Radeon HD 8400 R3 Series
- Hard_Drive_Capacity: 120GB SSD
- Monitor/Display Make & Model: Samsung SyncMaster 216BW
- Corel programs: AfterShot Pro 3
I confirm this issue. I recently installed ASP3 in a relatively recent install of Xubuntu 16.04 and I got the following message when starting `AfterShot3X64` from the command line:
Install Path: /opt/AfterShot3(64-bit) LD_PATH: /opt/AfterShot3(64-bit)/lib: XLIB_SKIP_ARGB_VISUALS: ./AfterShot: error while loading shared libraries: libgstreamer-0.10.so.0: cannot open shared object file: No such file or directoryInstalling libgstreamer-0.10 just caused AfterShot to complain about other missing dependencies:
Install Path: /opt/AfterShot3(64-bit) LD_PATH: /opt/AfterShot3(64-bit)/lib: XLIB_SKIP_ARGB_VISUALS: ./AfterShot: error while loading shared libraries: libgstapp-0.10.so.0: cannot open shared object file: No such file or directoryI managed to get rid of the issue by installing the following:
sudo apt-get install libgstreamer-plugins-base0.10-0
Ubuntu 16.10 now only has gstreamer1.0 in the official repositories. Would be nice if (meaning an immediate fix is expected) Corel fixed the linux build of ASP3 to be compliant with gstreamer1.0. Especially since gstreamer0.10 is not maintained since 2013.
Joelp
- System_Drive: N/A
- Video Card: GeForce GT 730
- Monitor/Display Make & Model: EIZO
- Corel programs: AfterShotPro
Hey, same issue for me. I contacted support and my last answer is
Hope that, they will fix it soon. For now, I have no machine with this old library.I require further assistance on this matter and will be seeking the help of our next level of support. I will get back to you shortly with a proposed answer to the issue at hand ...
Joelp
- System_Drive: N/A
Looks like, they don't care. For years. And maybe it's time to try Open Source solution again, sadly.
Joelp
- System_Drive: N/A
On new AfterShotPro3-360380:3.6-0.380.x86_64 guess what. Still same problem.
rjforster
- System_Drive: N/A
- processor: i7-8565U
- ram: 32GB
- Monitor/Display Make & Model: 1920x1080
- Corel programs: AfterShotPro3
Re: gstreamer0.10 dependency problem (now seen in Fedora 32)
I see the same problem on Fedora 32.
Trying to upgrade F31 to F32 fails due to dependencies for libgstreamer-0.10 and libgstapp-0.10 which are both in F31. With Fedora32 running on other hardware I see the same dependency problems when trying to install ASP3.
It worked great in Fedora 31. I note that the system requirements page still reads "Fedora®19 or Ubuntu® 14.04 or later (64-bit distributions)"
rjforster
- System_Drive: N/A
- ram: 32GB
Installing the repo from here: https://copr.fedorainfracloud.org/coprs ... eamer0.10/
let me upgrade from Fedora 31 to 32 with ASP3 still working. Note, it's the same file if you get the f31or f32 link.
Hope this helps a few others.
R
R
rstory
- System_Drive: N/A
That repo doesn't seem to be enough anymore. There is a workaround in this thread: https://forum.corel.com/viewtopic.php?f=94&t=67295
