Corel PaintShop Pro X8 Service Pack 2
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
Re: Corel PaintShop Pro X8 Service Pack 2
My experience is the same as csh2000's and we've discussed it at length in another thread. I have colour management on, set PSP monitor profile to the calibration profile, image, graphic etc. generated by sRGB Color Space Profile.icm and everything is consistent and stable - no colours jumping around. I don't print from my computer so if I did that I would need to do more adjustments, I'm sure.
Mark
dmart7
- processor: Intel i5-3570K
Yes, sadly it is the same problem with SP2. I had the well-known problem with SP1 and had to reinstall without SP1. I've just had to do the same with SP2. Rather unbelievable.flagpole wrote:Anyone know if this addresses the weird problem with SP1?
Or should i avoid it?
It seems to happen only on W7 and possibly with Nvidia graphics cards, and not all of them. I have a secondary PC with ATI card and it is unaffected. Some people, including Corel, seek to minimise the number affected, but people have given up, reverted to the original (without SP) or wouldn't dream of accepting SP2 after the SP1 problem. So we won't see many of them on this forum....
Simone Corel UK
- Alludo
@ flagpole » Thu Apr 28, 2016 4:35 pm
This issue has not been solved with SP2. Please do not install SP 2 but keep PSP8.0 installed.
SP 2 removed my 32 bit program and crashes with multiple errors of file access denied.
Can't use any 32 bit add ons like Perfectly Clear, but 64 bit still runs.
Lost as to what do expect uninstall everything in X8 Ultimate package and start over.
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Well, that's a new one!revsdm wrote:SP 2 removed my 32 bit program and crashes with multiple errors of file access denied.
Yes, I would suggest that you use the removal tools available in a sticky thread near the top of this forum and remove everything and then reinstall X8 without the service packs until they get the issues with Windows 7 worked out.
JoeB
Using PSP 2019 64bit
JoeB
Simone Corel UK
- Alludo
@ to all with the text issue (text is missing in menus) that came with SP 1 and was not solved in SP2:
We have finally nailed down the cause of the issue and released a fix.
For all customers who use PSPX8.0, please follow these steps:
Download SP 2 for PSPX8 from here:
http://www.paintshoppro.com/en/support/ ... duct-tab=0
Download the PSPX8.2_Text-missing.exe
https://drive.google.com/open?id=0BwT28 ... 3NmNHZ1YkE
1. Install SP 2 for PSPX8
2. Install PSPX8.2_Text-missing.exe
JoeB
- ram: 8 GB
Would I be correct in assuming that there is nothing else in the fix other than the missing text issue and so those of us who don't have that issue should not be installing the fix?Simone Corel UK wrote:@ to all with the text issue (text is missing in menus) that came with SP 1 and was not solved in SP2:
JoeB
JoeB
Simone Corel UK
- Alludo
@JoeB
Absolutely, who never had this "no text in menus" issue on Windows 7 64-bit doesn't need to install this fix because there is nothing to fix.
Last edited by Simone Corel UK on Fri May 20, 2016 2:24 am, edited 1 time in total.
dmart7
Thanks to Simone and Corel for getting this fixed
Simone Corel UK
- Alludo
Thank to you, dmart7, for your great help
