VideoStudio Pro Has Stopped Working....
DayO
motherboard: HP 18E7
processor: Intel Core i5 4750 CPU 3 20 GHz
ram: 32 GB
Video Card: Intel HD Graphics 4600 1024 MB
Hard_Drive_Capacity: 3932 GB
Corel programs: Video Studio Pro X9
Post by DayO »
When I tried to start VideoStudio Pro X7 on my PC, I got an error message that read:
"VideoStudio Pro has stopped working."
A Problem detail report says: "Fault module: Name is KERNELBASE.dll"
How do I get it to START working again?
I'm running under Windows 7 Home Version.
Re: VideoStudio Pro Has Stopped Working....
Post by BrianCee »
Have you been using Videostudio since the middle of February - or was your last use before that
DayO
ram: 32 GB
Post by DayO »
I believe I accessed--but didn't use--the program in March without any trouble.
But I first got the error message just yesterday.
Post by BrianCee »
OK - I was just checking as everyone on Windows 7 had a problem of Videostudio not starting after a Win 7 update in mid Feb
It does not sound as though that is the same problem as you have - but if you have not yet installed the latest hotfix it might be worth installing it just to eliminate the win 7 update as causing the problem
The hotfix can be found here :- http://www.videostudiopro.com/en/suppor ... sion-tab=2
DayO
ram: 32 GB
Post by DayO »
Thanks - I'll try that hotfix to see if it solves the problem.
DayO
ram: 32 GB
Post by DayO »
That hotfix says it works with VideoStudio X7 - Does it also work with the X7 PRO version?
Thanks!
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
The Hot Fix works with both versions of VSX7, Pro & Ultimate
DayO
ram: 32 GB
Post by DayO »
I installed and ran the HotFix--that did the trick! VS Pro X7 functioning OK.
Thanks for the info!
(I wonder what caused the program to malfunction in the first place....)
