Is there any forum section for Boris Graffiti?
rkstudio
- motherboard: There is no motherboard listed
- processor: Intel Core i7-855ou CPU 1.80 GHZ
- Video Card: Radeon 540 Graphics
- Hard_Drive_Capacity: 256 SSD
- Monitor/Display Make & Model: Radeon 540 Graphics
- Corel programs: Videostudio 2020 Pro
I was wondering because I just started using Boris Graffiti and I think it's something that will be useful to me. However, when I click "text", there are no fonts there. Does anyone know where I can get some answers for this or does anyone know the answer.
Thanks, Bob
Thanks, Bob
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Re: Is there any forum section for Boris Graffiti?
To access Graffiti click on FX filters then drag the Boris Graffiti filter onto your video clip, then highlight and select Options, this will open the attributes panel, then select Customize Filter, now you will have access to the full range of text
- RobertOZ
For some tutorials on using Boris Graffiti go to Gripps YouTube channel
https://www.youtube.com/user/gripps2211
JaRo
- motherboard: ASUS K556U
- processor: Core i5
- ram: 12 Go
- Video Card: NVidia GEForce 940mx
- Hard_Drive_Capacity: 1 TB
- Corel programs: VS, Draw, PaintShop, Motion 3D
In Documents of the link in signature below, there's a file called « boris.xlsx, xls or pdf » with the names of 102 videos I've found on the Web. Some videos are made for Avid, Pinnacle, Boris Red. Nevertheless, just about all of them use the same principles/rules than Boris Graffiti with VideoStudio or, at least, are pretty close. You should be able to copy the name, go to the Web, paste the name and see them on the Web.
VS Ultimate X4,X5,X6,X8. MotionStudio 3D, CorelDRAW X5, PHOTO-PAINT X5, PaintShop Pro X4
Lots of free stuff, explanatory documents : https://1drv.ms/f/s!AqzpHEzjQAwYkFiTJS6xeWPbPBsM
rkstudio
Hello Robert,RobertOZ wrote:To access Graffiti click on FX filters then drag the Boris Graffiti filter onto your video clip, then highlight and select Options, this will open the attributes panel, then select Customize Filter, now you will have access to the full range of text
The only place I have access to BG is on the desktop. I have an icon there where I can access it. But there is no filter in FX that is Boris Graffiti....or anywhere else in VSX6.
I don't know if it's the way I installed it or not, but maybe I can put the disk in and load it into VS.
rkstudio
Well I got it to load and install into VS by using Disk 2 with the special effects. Now I have it as a stand-alone and installed in VS. I don't know if i need the stand-alone still installed on my computer or not but I don't want to mess anything up either.
Now I have to figure out BG. That looks like a task!!!
Thanks for your help, you guys!
JaRo
- ram: 12 Go
I would suggest you to keep it as a stand-alone. It will allow you to do what you want, save your project as a « grf » file, come back to it either in the stand-alone or with VideoStudio when you apply the Boris Graffiti FX on a video/picture/colour, make a choice from the Library.
If you look at Gripps videos, you should learn a lot easily and quickly. Once you'll understand how Keyframes work, you should be able to do lots of nice things.
rkstudio
Thank you. I'm starting to find out that keyframes are a big deal in BG. Last night, I made a cube with the help of a video I saw on how to make one. It wasn't a Gripps video, but it was good. The only thing is, he didn't say how to save the project. It's not self explanatory like most other programs are. Afterwards, after I lost the project for not knowing how to save it, I learned that you have to click apply on the bottom right. Anyway, live and learn. I think Boris would sell a lot more if they made a good manual and some instructional videos.
- RobertOZ
The following tutorial shows you how to render and save projects in the standalone version of 6.1 and import into VS
https://www.youtube.com/watch?v=sVvg_Zx ... leYsr7Ai9M
JaRo
- ram: 12 Go
In Boris Graffiti, go to « Help / Boris Graffiti User Guide ». You should get : C:\Program Files (x86)\Boris FX, Inc\Boris Graffiti 6\Documentation\wwhelp\wwhimpl\js\html\wwhelp.htm.rkstudio wrote:I think Boris would sell a lot more if they made a good manual and some instructional videos.
In the link below(onedrive), go to « Documents / Graffiti LTD User Guide ». It's an old version, but it could help you.
This site could also help you : https://www.borisfx.com/products/graffiti/
Other sites : http://cdn.borisfx.com/borisfx/download ... 0Guide.pdf
https://www.borisfx.com/training/videos ... order=DESC. You might find something else on the Web. Remember, there are tutorials / publications / videos about Boris Red that can be applied in Boris Graffiti.
