MPG clips are playing black in VS X9
cdoughertycd
motherboard: ASUS PHTD DELUXE
processor: 4 Core 2-93 gigahertz Intel Xeon
ram: 36 GB
Video Card: AMD Radeon HD 7700 Series
sound_card: AMD HD Audio
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Samsung S24B300
Corel programs: many back to VS 5, all up to 2022 Ult
Post by cdoughertycd »
Would anyone know why MPG clips (not the whole project) in VS X9 are playing black but there is audio?
thanks so much.
Candy Dougherty
Re: MPG clips are playing black in VS X9
Post by BrianCee »
where did these MPG files come from - what are their properties
please right click on one of them in the timeline of Videostudio and choose "properties" from the pop out - screen shot the properties box and attach it to your answer
cdoughertycd
ram: 36 GB
Hi Brian:
Here is screen shot of one of my MPGs that play black as a clip in the library and as a clip on the timeline. I can see it however on the timeline if I click on the whole project.
This MPG was converted from MPEG-4 from my Android phone. The MPEG-4 files crash my VS X9.
Thanks for your help.
Candy
Post by BrianCee »
Two things struck me as I looked at your preferences - if you are in the USA your copy of Videostudio will be expecting to see a frame rate of 30fps (29.97) - it could be not liking the 23.96 in your files - - the bit rate is a bit high for a standard mpeg_2 - usually we use a maximum of 8000
can you change the parameters in whatever programme you are using to convert to use 30fps and 8000kbps
canuck
operating_system: Windows 8.1
Post by canuck »
cdoughertycd wrote:Would anyone know why MPG clips (not the whole project) in VS X9 are playing black but there is audio?
thanks so much.
Candy Dougherty
Could you perhaps upload (to OneDrive or Google drive or some other site) a original unconverted short clip for us to play around with?
cdoughertycd
ram: 36 GB
Canuck & Brian: Here is original MPEG-4 from my Android phone, 7 seconds. It loads into the library (X9) but when I click on it to play or try to drag to timeline, X9 crashes. When I convert to MPEG-2 clips play black with video but I am able to see the video as a "project" on the timeline.
https://onedrive.live.com/redir?resid=1 ... ideo%2cmp4
Thanks for all your help.
Candy
cdoughertycd
ram: 36 GB
Brian: While Canuck is looking at the MPEG-4, I will try changing parameters in conversion.
Thanks,
Candy
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
Hi Candy,
Downloaded your clip, plays fine in VSX9 in both clip and project mode
cdoughertycd
ram: 36 GB
Robert: Hm, interesting.
Now to try to figure out why I can't play MPEG-4 in X9. I did hide 3 Windows updates to try and get VS X6 to work.
Will see if Brian or Canuck have any input.
I remember a similar problem with black video in another VS version and can't remember the solution, possibly a .dll, but it's too long ago.
My OS is Windows 7 Premium, 64 bit.
Anyway, thanks for checking it.
Candy
Los Angeles
I also had no trouble playing that clip in both Clip and Project mode in my fully up to date X9 running under Windows 10.
I might note, though, that the Properties I have for that clip show a frame rate of 30.007 fps, which nevertheless still indicates it is of the variable framerate type which VS seems to have problems with for some people. I would also note that that clip shows as an mpeg-4 file not mpeg-2, and has a different number than the one Candy showed the Properties of above.
canuck
Post by canuck »
No problem playing the clip with VS X9 on a W7 system in both clip and project mode.
cdoughertycd
ram: 36 GB
Yes, Ken on the properties I posted, that was for the converted MPEG-2, converted from the MPEG-4 clip I put on One Drive. The MPEG-2 clips play black when in the library but audio works, they play ok however as a project on the timeline. The MPEG-4 crashes VS X9.
I'll try to figure out the frame rate thing, maybe that's the problem.
Thanks for testing it.
Candy
zoroku
Post by zoroku »
You'll find lots of issues about "MP4 crashes VS". I'm afraid these mp4 files are encoded by MPEG-4. Once I change mp4 to mkv (H.264), it works. Surely, H.264 has a very broad application range and MPEG-4 is used to compress AV data for web streaming, CD distribution, voice (telephone, videophone) and broadcast television applications.
Post by BrianCee »
Your clip works absolutely fine in my version of X9 Candy - plays from the library or the timeline in clip or project mode
just a thought - can you confirm your version number - "Help >> About" - string of 4 numbers starting 19.
cdoughertycd
ram: 36 GB
Hi Brian: My X9 Pro version numbers are 19.1.0.14 (64 bit Pro).
thanks for your help.
