Is there any way to apply a chroma key filter and a mask frame onto the same overlay clip? I'm using x7 but I'd be willing to upgrade to a later version.
I want to create a shot where a green screened character appears to pass through a portal and changes appearance on the other side. So I would overlay the same clip twice, apply chroma key to eliminate the green screen, then use mask frames on each clip to hide the left and right side accordingly (then apply some other FX to make one side look different).
I could easily crop each clip, but I would much rather have the intersection of the two clips be a complex shape to look more realistic.
Thanks for any input,
FB
Chroma key and mask frame on same clip?
fingerbreaker
fingerbreaker
Re: Chroma key and mask frame on same clip?
I thought of a potential workaround: Create a solid green main clip; apply the overlay clip and use a mask frame on it; render that project. Now I can import that new clip and apply chroma key to it. The end result should be that the original clip now has both a mask frame and a chroma key applied to it. Maybe that's obvious to experienced users, but for me it feels like I just solved Rubick's Cube!
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
You missed one tip.
You don't have to render, you can save one solution as pre1.vsp and than reload it to Final.vsp and apply further keys.
Panasonic X900m, VXF1
JaRo
- motherboard: ASUS K556U
- processor: Core i5
- ram: 12 Go
- Video Card: NVidia GEForce 940mx
- sound_card: Realtek
- Hard_Drive_Capacity: 1 TB
- Corel programs: VS, Draw, PaintShop, Motion 3D
Hi fingerbreaker,
Here are a few links about mask and green/blue screen. Hope they can be of any help.
1. Corel VideoStudio Pro x8, combine mask with green screen : https://www.youtube.com/watch?v=FJRsuDAj234
2. Tutorial: NewBlueFX Video Essentials VI : https://www.youtube.com/watch?v=92XArlG8u5A
3. Corel VideoStudio Pro x6, green screen white-snow issue fix : https://www.youtube.com/watch?v=XmnlCHowg_k
4. Corel VideoStudio Pro x4, blue screen part 2 : Corel VideoStudio Pro x4, blue screen part 2
5. Corel VideoStudio Pro x8, freeze frame : https://www.youtube.com/watch?v=uulL_7o8REk
6. Corel VideoStudio Pro X8: Drop Shadow and Chroma Key Filters by Gripps : https://www.youtube.com/watch?v=uE-jlHx3zOk
Many other good tips within gripps2211 : https://www.youtube.com/channel/UCF15vJ ... cHMh2UOvDg and
freedomearthmoon1 : https://www.youtube.com/channel/UCaFTRq ... RYWOxsHMUg
I don't know what exactly you want to achieve, but sometimes we should think a little bit more often at Boris Graffiti that comes as a plugin with VideoStudio.
Also, if you want more, see the link in the signature below. In the videostudio file, if you type green or screen or chroma or mask in the search tool of Excel, you will get lots of results. You can copy the name of any result and paste it in Google or other search tool as to view these videos on the Web.
VS Ultimate X4,X5,X6,X8. MotionStudio 3D, CorelDRAW X5, PHOTO-PAINT X5, PaintShop Pro X4
Lots of free stuff, explanatory documents : https://1drv.ms/f/s!AqzpHEzjQAwYkFiTJS6xeWPbPBsM
fingerbreaker
asik1 and JaRo: thank you very much for your replies. Very helpful - I think I'm on the right track. The more I know the more I realize I don't know!
