CVS appcrash after closing
ekkl
motherboard: Gigabyte
processor: Intel CoreDuo E7400 2.8GHz
ram: 4G 333MHz
Video Card: Geforce 512Mb
sound_card: internal
Hard_Drive_Capacity: 640Gb
Monitor/Display Make & Model: aseu 22"
Corel programs: VS MS
Post by ekkl »
CVS x9, SP1
In some seconds (6-14) after closing program pop a window up with an error message (Program was terminated e.s.w APPCRASH)
This is not always, but often enough. Usually when there timeline has files.
I understand that program crashes already during the closing, and data is not lost, but it is not very pleasant.
Version x8 no such this problem.
OS: Win7 SP1
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: CVS appcrash after closing
Post by RobertOZ »
If VSX9 is the only program that you see this message on closing, then it may be resolved by reinstalling VSX9
Like you, I get the same error every time I close VSX9 and if you open task manager and check processes you will see that vstudio.exe is still running, so the program is not shutting down correctly, hence error message, for me this only occurs with imported media, if I just (as a test) drag sample videos only to the timeline then close, the error does not appear. As the program is otherwise behaving correctly I can live with it and as the program is set up how I want it, I'm not inclined to consider a reinstall yet.
RobertOZ
Post by RobertOZ »
Also, make sure you empty the Dump Store, just checked mine and found 73 vstudio.exe.dmp files and as these are of no use, unless Corel request you send them to support, they can be deleted
RobertOZ
Post by RobertOZ »
After installing SP2, for me, this problem has disappeared, program now closes correctly, will take note and report back, if the problem reoccurs on a regular basis
