Am I doing something Wrong.?
I mean like I am using new 200G sata HDDs(hot swap) to (only) archive video and every half hour or so I find the HDD gets quite fragmented.
Is that normal.? There's nothing else on the HDDs that I'm using to archive
Video Capture - Minimizing HDD fragmentation
I presume you are using NTFS, This has a peculiar way of splitting the clusters into two with some of the system files at the start and at the middle. This means that files may be deliberately fragmented. Some defraggers show this anomaly while others conceal it from view. I know of no way of stopping this behaviour.
FYI: I always reformat (full) my video disc (as opposed to defragging it) before starting a major project.
Terry Stetler
jjoshua
Yes I'm only archiving on the HD in Question and as I,ve mentioned,
this happens to a new blank HD which was just formatted.
Would using fat32 help. For every one hour of .avi that is captured(from a DV cam)to the newly formatted disc, I have to defragment for about the same amount of time or more. If that is normal or if there is no way around it, then I'm still one happy archiver. But if I'm suffering unnecessarily, would someone kindly enlighten me
John
John
If your files are more than a couple of gigabytes or so, then I don't think that defragging will stop some fragmentation in NTFS. Some frag is perfectly acceptable. Just think, I use RAID 0 and every video file I have is fragmented between two disks. What is not desirable is having a video file fragmented in a single disk into a myriad of bits just a few Mb each, higglety-pigglety over the place. If you start with a freshly full-formatted disk and you just save a number of poly-Gb files, I'd say ignore the minor fragmentation that may result. You probably won't improve on the results. And I would not recommend FAT32.
jjoshua
going to continue defragmenting HD after capture.
I think I exagerated the time taken to defrag. It actually takes me about half the time to defrag that it takes to capture now that it is under more scrutiny.
If the file size is not an issue (none of my clips reach 4G) are there any other reasons not to use Fat32 ?
jjoshua
Like I said , it actuallt does'nt take as long to defragment as I thought (using diskeeper lite defragger-am cosidering getting perfectdisk 7)
Do you think it is better to partition the archive HD ? It's a little late for the present HD I'm using but I would consider partitioning my other HDs if I get more feedback.
