I have asked a similar question before about copy/pasting title tracks from one project to another. But this question is different. I am working on a larger project that will contain several smaller sections. I have started the overall project and things are going well. I have also made and tested the second section. I do this because it is easier to make, fix and render the smaller piece. How can I take this smaller piece now, and copy/paste it onto the end of the larger main project?
Thank you in advance
Regards
Pierre
copy/pasting a whole project
Re: copy/pasting a whole project
Hi Pierre
I assume you have two projects VSP files.
Open the main project, showing on the timelines.
Add the second project VSP to the library, as you would a normal video clip using the Import Media files.
Drag the VSP from the library to the timeline.
If you press Shift the project will be added as a single clip otherwise will open in its expanded view.
pblais
- Corel programs: Videostudio x9 ultimate
once again Trevor... that was easy as pie... thank you very much for you help
