NewBlue Film Effects
Pete Waterman
- processor: Intel Core i7 7700
- ram: 12gb
- Video Card: AMD Radeo R5 435
- sound_card: Realtek alc888s-VD Audio
- Hard_Drive_Capacity: 3 TB
- Monitor/Display Make & Model: Samsung
- Corel programs: Video Studio Ultimate 2019, 2021, 2023
Hi All
Ive just installed VS X9 Ultimate (download version) with it you get NewBlue Film Effects.
On installing this i noticed something I thought was odd?
This image is showing the Newblue is for VS X8 This is showing the installation Assistant for Magix (I don't have any Magix programs installed) the next image is for the installation Assistant for Magix 64 bit The last one shows it is all installed in a Magix folder C:\ProgramData\MAGIX\Common\VfxPlugins Is this correct and if so how do i access NewBlue Film Effects through VSX9?
I know that you believe you understand what you think I said,
but I'm not sure you realize that what you heard is not what I meant.
Re: NewBlue Film Effects
I access all my New Blue effects via the drop down in the FX library
Pete Waterman
- ram: 12gb
Hi Brian
That's how I get to all the New Blue effects Mine is the same as yours but there is no "New Blue Film Effects"
Hi Pete
Do you have X8 installed?
If so you may be able to copy the files across to X9, although not ideal.
I think you should contact Corel Support and ask for the X9 version.
Hi Pete
Just noticed the first image showing Add path, if you target the X9 folder it may install ok?
Pete Waterman
- ram: 12gb
Thanks Trevor
To be honest I didn't see that, Douh
For some reason the new VS X9 Ultimate is installed in C:\Program Files\Corel\Corel VideoStudio X9, and not C:\Program Files\Corel\Corel VideoStudio Ultimate X9 as with X8 C:\Program Files\Corel\Corel VideoStudio Ultimate X8.
I uninstalled the New blue film effects, reinstalled it on the path of C:\Program Files\Corel\Corel VideoStudio X9 checked everything else (very carefully) I didn't change any other setting and its now installed and no mention of Magix at all!
Hi Pete
Glad you managed to install the pack.
Installation Folder
I have the same folders as you describe, to be honest I have installed X9 many times and not really taken note of the folder name, but yes no Ultimate in the folder name.
Installation Folder
misa
- motherboard: msi BOARD
- processor: i7 quad core 870
- ram: 8 GB
- Hard_Drive_Capacity: 240 gb ssd
- Monitor/Display Make & Model: INSIGNIA
- Corel programs: video studio x9
Hmm, got the video studio x9 and come with NewBlue Film Effects free and i can not figure out how install and make the NewBlue Film Effects show up in FX drop down!
Have Windows 10 and the Corel install is in: "c drive (local drive) /program files/corel/corel videostudio x9/...all files here are from the install."
I have un-installed the new blue soft "Film Effects" and while trying to install back , i don't get that "path" screen anymore , anyway not sure what exactly to do to make it work.
Any help will appreciate.
Hi misa
Welcome to the forums
Unfortunately I never received that pack so cannot even try to replicate the installation problem.
Strange that it is no longer giving the option to Add Path.
I can only suggest you contact Corel Support to report the issue.
Clearly it should not default to X8 as it seems to be doing.
If you have X8 installed then it may be possible to copy the Vfx-Plugin files across to X9, not ideal I know, Again I cannot advise which files they are.
misa
- ram: 8 GB
Yes, i may contact Corel support.
You can get Corel video studio x9 w/that free newblue addon for $14.99 , i guess is in sale . And i do not have x8, just purchased x9 directly.
