Canon 7DMk2
pgman
operating_system: Linux
System_Drive: N/A
Canon 7DMk2
Post by pgman »
I've been a long term user. I stopped with 2.1 because of too many crashes.
I just reinstalled ASP with 2.4. It's much more stable, but it doesn't recognize my camera: Canon 7DMk2. It's fairly mainstream camera that has been available for a year and half. :shock:
Does any has a profile for it?
Dutchmm
System_Drive: N/A
motherboard: Asus 97
processor: Intel i7 4785T
Video Card: Onboard Intel
sound_card: Intel AC97
Hard_Drive_Capacity: 2.5TB
Monitor/Display Make & Model: Philips 28"
Corel programs: ASP 3 Pro (and 2 and 1 before)
Re: Canon 7DMk2
Post by Dutchmm »
I ran strings on the binary, and the 2.4 version can process images from your 7DMk2. What it won't do - at least without some work from you - is apply optical correction to the RAWs it develops. I haven't got time to try this out (or a 7DMk2 ;-() ) but perhaps you could create a set of camera defaults that would check the Lens Correction tab, select Canon as the manufacturer, and the 7DM2 as the model. You could even pre-select your favourite lens as part of the default.
So far, so easy. You will also need to create a correction profile of your own for the lens database. Read AFX's book on this, if you can't get enough howto from this forum.
HTH
pgman
System_Drive: N/A
Re: Canon 7DMk2
Post by pgman »
Yes and no.
I can open the 7dmk2 files, at first they (the jpeg previews) are sharp and crisp, then after a few second the image displayed becomes 'extra soft'.
I have tried with sharpening... I can't get it back.
I think that it has to do with the demosaic and ASP takes it from another camera that doesn't match the 7DMk2.
Dutchmm
System_Drive: N/A
Re: Canon 7DMk2
Post by Dutchmm »
You tried sending them to an output batch? Call me suspicious, but I only do the coarsest cull on the basis of what I see in the preview screens.
And I take it you have tried the wavelet sharpening plugin? I have this as a camera default, because the results with all of my A-Mount lenses, whether Minolta, Sony, or Sigma are always a little too soft without it.
pgman
System_Drive: N/A
Re: Canon 7DMk2
Post by pgman »
Dutchmm wrote:You tried sending them to an output batch? Call me suspicious, but I only do the coarsest cull on the basis of what I see in the preview screens.
No, I haven't. When I look at my photos from the Canon 7D (my previous camera), they are good, they are not 'soft'. And I don't have that problem with the images of the Fujifilm X-T10. It's only the the 7Dmk2.
* First I load the images
* Quick look and decide to keep or delete (with flags). Focus, composition....
* Delete the rejected flags
* Rename the files to seomthing that make sense (to me)
Then, I will process a few images...
But the problem is that I can't judge the focus when the image is soft.
Dutchmm
System_Drive: N/A
Re: Canon 7DMk2
Post by Dutchmm »
Given the wavelet sharpen plugin is free, you might try creating a camera specific default that applies a mild sharpening when you load images from that camera into ASP. On the whole I can tell the difference between (oof and sharpened) and (tack sharp and sharpened a bit more). Even in preview. Which I then verify against all but the throwouts.
