ASP 2.4 on OSX Yosemite. ASP just sits there doing nothing wile the files are queued. I cant believe such a buggy product is a major release !!
Anyone got a fix?
Output Jpeg or Tiff - nothing happens
D L
- ram: 4GB
- Corel programs: AfterShot Pro 2
Re: Output Jpeg or Tiff - nothing happens
I have a similar issue on Windows 10 with 2.40.119 x64 with Nikon .nef raw files (I haven't tried any other raw files)
I can export a file once. However, it's when I go back and do an edit that I sometimes have trouble re-exporting. It will queue, but not export, same as the OP.
I haven't worked out the common factor that causes this bug as it doesn't happen to all files. It could be files with layers, or files I have previously exported to an external editor, but not certain at this point.
The work around (that works for me anyway) is to:
Close Aftershot,
Delete the .xmp file for the image
Re-open Aftershot
Re-edit the raw file
Export as normal
This is super annoying, especially if all I want to do is a full res and a web version of the same edit.
I have used several previous versions of Aftershot Pro 2 and never had this problem with any of them.
Close Aftershot,
Re-open Aftershot
Export as normal
