Using the "Quote" facility
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
Have never used this.Do you just highlight the text in a post and click on quote when you want to refer previous text in a post ?
Re: Using the "Quote" facility
Ken Veal wrote:Have never used this.Do you just highlight the text in a post and click on quote when you want to refer previous text in a post ?
no need to select any text, just click the Quote link
then complete your reply and submit
There are a couple of ways of going about this. One is the way Trevor just suggested. That will copy the entire post you want to quote from, but will automatically include who said it i.e. the "Ken Veal said" part. It's fine if the question is as short as yours was that Trevor "quoted". However, if you only want to quote a line or two from a much longer post, you must then delete the parts of the Quote you don't want.
I usually opt for another way. I in fact select and copy the text I want. Then in my reply I hit the Quote button above the 'Post a Reply' box (to the right of the B, I and U buttons). You will see [quote][/quote] appear. You position the cursor between the ][ brackets and paste in the text you want to appear. You don't automatically get the "Ken Veal said" bit, but often this does not matter if your post with the Quote is immediately following that post or very close to it.
However, it you want it, it's easy enough. You go back to the [quote] part and add an = symbol, followed by the name of the person who said it in quotation marks: [quote="Ken Veal"].
Some might find this a bit more labour intensive, but I find it takes about as long as it would to use Trevor's method then go through the text deleting the bits you don't want.
Up to you, really...
Ken Veal
ram: 32 GB
Post by Ken Veal »
A few observations on this issue-
1 Trevor’s suggestion is fine if you need to quote the whole text , this method also supplies the author’s name.
2 So far when using this forum I have only had occasion to quote a a small selection from a previous post and because I have not figured out how to show a quote as discussed here I have used quotation marks.
3 Which brings me to the fact that before this post I did look for anything on using the quote button including “Please read this before posting” but could not find anything on it .Not a big issue, but I thought it would be somewhere.
4 I think I would lean towards the select and copy method which I tried as follows
5 Select and copied appropriate text
6 Clicked the Quote box(red text) on the right hand side
which shows a tool tip in black giving the name of the person about to be quoted.
7 This brings up another quote option box above the “Post a
Reply “ box
8 Positioned the cursor between the ][ brackets and pasted in
the text
Below is an example of the result I get (I typed in =Ken Berry myself)
=Ken Berry
Which is not the expected result? Is this something to do with having the red text quote box on the right showing or not ?
Ken Veal
ram: 32 GB
Post by Ken Veal »
As you where, the big text box does not show around the text until it has been posted
Ken Berry wrote:... followed by the name of the person who said it in quotation marks:....
As I said above, the name of the person you are quoting has to itself be in quotation marks "..." i.e. apostrophes.
Ken Veal
ram: 32 GB
Post by Ken Veal »
You are of course correct Ken -something I overlooked
