Thumbnails X8
kiwozikonnections
Thumbnails X8
My apologies in advance if I'm in the wrong place here (I'm not great at Forums).
OS - Win 8 x 64; PSP X8 x 64
Along with many other users I see, I can no longer view thumbnails for psp files in Windows Explorer. I have only just upgraded from X6 and they were all visible back then.
They display fine in "PSP Manage", it only seems to be Windows Explorer and psp type files that have the problem. I have checked the Always show icons never thumbnails etc setting and they are all OK but still no luck.
It appears from my reading, that the only solution at the moment to make my newly purchased X8 work properly is via additional 3rd party software (which I am not prepared to do).
Any other solutions/suggestions would be greatly appreciated.
Cheers.
Cheers.
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
Re: Thumbnails X8
You could use the freebie from Bot productions, but am not too sure if it still works :
http://www.botproductions.com/pspthumb/index.html
Or, the one I have used for years, Mystic Thumbs, which is not just for seeing .PSPimage thumbs, but many other obscure file types.
http://mysticcoder.net/mysticthumbs.html
It is not expensive.
Hope that helps.
Joëlle
Hope that helps.
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
- hartpaul
- ram: 8 Gb
Re: Thumbnails X8
I am using Windows 8.1 on a Toshiba laptop and the thumbnails of psp files show correctly.
I opened up a folder in windows (PSP not opened at all) that contains jpgs and psp files. I clicked on View and Large Icons was highlighted.
Then over at the right hand side I clicked on Options > View and made sure that Always show Icons, never thumbnails was unticked, Display file icon on thumbnail was ticked.
I have Hide extensions for known file types unticked.
kiwozikonnections
Re: Thumbnails X8
Thanks for the replies guys.
Like I said. . . not prepared to enlist 3rd Party "Bot" or "Mystic Thumbs" software just to get PSP to work properly
Its just a matter of principal I guess (albeit that I might be cutting off my nose despite my face) and I have no thumbnail issues with any other file types.
Hartpaul - yep thanks - tried those. . . no fix.
Guess I'll have to settle for viewing thumbnails from within in "PSP Manage" rather than Win Explorer
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Re: Thumbnails X8
If you read hartpaul's post you'll see that it works fine for him. So that would rule out it being solely a PSP issue.kiwozikonnections wrote:Thanks for the replies guys.
Like I said. . . not prepared to enlist 3rd Party "Bot" or "Mystic Thumbs" software just to get PSP to work properly![]()
JoeB
Using PSP 2019 64bit
JoeB
kiwozikonnections
Re: Thumbnails X8
Yes of course. . . .Wow I wonder if all the others out there with the same problem realise that the issue is really their PC's are not compatible. God forbid a workman blames his toolsIf you read hartpaul's post you'll see that it works fine for him. So that would rule out it being solely a PSP issue.
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: Thumbnails X8
I have Win 10 64bit and PSP X8.1.kiwozikonnections wrote: OS - Win 8 x 64; PSP X8 x 64
Pspimage thumbnails are showing fine on my system without third party software.
My previous OS was Windows 8 and they were showing fine too.
At first, Windows Explorer needs some time to show them and you may think they will not appear. But when they appear, display is always immediate.
JoeB
- ram: 8 GB
Re: Thumbnails X8
Nothing wrong with blaming your tools if, in fact, you are blaming the actual tool that isn't working. Windows Explorer, which is not part of PSP, seems to be where you're having your problem, so why you are suggesting that the tool with the problem is PSP is beyond me. Like Jean-Luc and hartpaul, I have no problem seeing PSPimage format files in Windows Explorer with Windows 8.1. I have both PSP X7 and X8 installed, but given they are not tied to Windows Explorer I don't see where it matters which version of PSP you have installed. If Windows Explorer is able to natively show PSPimage files, and if it does so on some people's computers, then if it doesn't do so on other people's computers that suggests a system incompatibility problem, and the incompatibility search should start with the program that seems to exhibit the problem - in this case, your (and some others') Windows Explorer.kiwozikonnections wrote:Yes of course. . . .Wow I wonder if all the others out there with the same problem realise that the issue is really their PC's are not compatible. God forbid a workman blames his toolsJoeB wrote:If you read hartpaul's post you'll see that it works fine for him. So that would rule out it being solely a PSP issue.
In case you were unaware of it, the third party software mentioned by others do not plug in to PSP. They plug into Windows Explorer, and were developed as add-on utilities for Explorer which has been known to sometimes be deficient in its ability to properly render thumbnail images of some formats.
JoeB
JoeB
Re: Thumbnails X8
Just for the record, you can add me to those who have no trouble seeing an image for .pspimage thumbnails in Windows Explorer in Win 10 x64. I have PSP X6, X7 and X8 installed on this computer.
kiwozikonnections
Re: Thumbnails X8
Problem Solved
This was originally a Digital Download installation ( i.e. not disc ). I did a complete uninstall/reinstall of the full "PSP Pro X8 Ultimate package" and hey presto all is as it should be and I can see all my files.
Thank you to all those who offered constructive posts.
JoeB
- ram: 8 GB
Re: Thumbnails X8
Thank you for reporting back on having solved your issue. I would say that my PSP X8 was also a download installation, not disc, and I didn't exhibit your issue. Still, glad to hear that yours was solved with a disc installation, although not sure why that should have been necessary.kiwozikonnections wrote:Problem Solved
This was originally a Digital Download installation ( i.e. not disc ). I did a complete uninstall/reinstall of the full "PSP Pro X8 Ultimate package" and hey presto all is as it should be and I can see all my files.![]()
As to your last comment, I would have thought that all posts by those trying to help with your issue - which might be one others experience also - were constructive. JMHO, of course.
JoeB
JoeB
