Favorite Paths List
DebbieH
- motherboard: Wistron 303C 08.60
- processor: 2.10 gigahertz AMD Athlon dual core QL-64
- ram: 160.4 gb
- Corel programs: PSP X5
Favorite Paths List
Help! I have to produce a series of product photos and save them by putting them in the favorite paths list. Now, this list has grown so long and I cannot get rid of it! Can anyone PLEASE tell me how I remove the lists? I have Paint Shop Pro X5. Many thanks.
- hartpaul
- ram: 8 Gb
Re: Favorite Paths List
I did a search for favorite paths list in PSP and found this link:
http://suzsplace.com/tips&tricks/vi-tips141160.htm
and it is mentioned in point 153 where Suz says:
"While this might be handy for the File...Open dialog, do not use it for any of the File...Save dialogs! Saving files there invites trouble: "
I tested that by setting up a desktop folder and using file open to navigate to that folder and then adding that to the favorites list . I then used the Remove to remove that item from the list and it was successful.
I could also see a Remove action as well. So it looks as if you might have to navigate to each folder and then using the Remove to remove that path.
LindaSue
- motherboard: Gigabyte
- processor: 2.71GHz AMD Athlon II X2 215 processor
- ram: 3 GB
- sound_card: Realtek AC97 Audio [onboard]
- Hard_Drive_Capacity: 1320 GB
- Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
- Corel programs: Paint Shop Pro X2, X4, X6
The problem is that if you've removed the folder or file the "favorite path" gets stuck in the list. To remove it, you''ll have to recreate the exact folder/file path then use the Remove feature.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
