Ubuntu 16.04 beta 2 and ASP 2.4
dFlyer
- System_Drive: N/A
Yesterday decided to give the new LTS Beta a try. Looking nice but still has some bugs. Installed ASP 2.4, but was not able to get the program to run. Has anyone tried and got this program to work under the beta.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Re: Ubuntu 16.04 beta 2 and ASP 2.4
Hello,
Install libgstreamer0.10-0 and it will do the trick
. On my computers, Asp seems to work flawlessly on 16.04. in my experience, the only software broken for now is google earth...
dFlyer
- System_Drive: N/A
Thanks. Will give it a try and post back.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
dFlyer
- System_Drive: N/A
Went and installed libgstreamer0.10-0 as noted above. Still will not start for the command line it gives the following error:
./AfterShotPro: error while loading shared libraries: libgstapp-0.10.so.0: cannot open shared object file: No such file or directory
Anyone know how to get this file in Ubuntu 16.04? Did a search of the repositories and couldn't find it.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
It seems to be a missing dependency again.
Now you have to install : libgstreamer-plugins-base0.10-0
If you are lucky, it could be the last missing...
I didn't have this problem because my 16.04 weren't fresh install.
Fortunately, the next version of ASP will likely be fully compliant 16.04 out of the box... wait and see!
dFlyer
- System_Drive: N/A
Looks like that fix it. Thanks. Still has the drag and drop bug but same fix seems to work.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
philfree
- System_Drive: N/A
I installed 16.04 and could not get AfterSot to run. It was giving me the similar errors about shared files but, it was a different file name. Sudo apt-get libgstreamer0.10-0 and then libgstreamer-plugins-base0.10-0. Fixed my problem thanks. I was about to go back to 14.04 until I came across this thread. Thanks again!
