swf files no longer work in X8 Ultimate
MikesMovies
- motherboard: Gigabyte Technology Co ltd H81M-DS2V SOCKET 0
- processor: Intel Core i5 4460
- Video Card: NVIDIA GeForce GTX 1050
- sound_card: NVIDIA Virtual Audio Device
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: PHL 242B1
- Corel programs: Video studio X10 and PaintShop Pr
Really annoying problem, for some reason the sample videos etc no longer work!
I get an error message.
Please see this screen play for details.
https://youtu.be/fI9i842yEro
Re: swf files no longer work in X8 Ultimate
When we had a previous user with the same problem Corel provided a "one off" fix - only problem is it was for X9 - but it may be worth a try on your system
it doesn't seem to want to attach to the forum - maybe to big - I'll add it to an e-mail to you Mike
forum e-mail wouldn't let me attach a zip - so it's coming from my personal e-mail
Hi Mike
A strange behaviour where the re-link seems to target other versions, especially for clips installed with the Contents package, I think, for you its looking for X7.
The first few clips being installed by the Main program targets X8?
You will have to reset the program by re-naming the 18.0 folder.
http://lata.me.uk/corel/reset/reset.htm
You could however try installing the Contents file again, maybe that will overwrite the library content. Would be interesting to know if that fixes things.
Installing that may also reset the library loosing your personal pages.
I would do a Library Manager Export to save a copy, even so may not work when importing again.
Brian can you provide me with those details, cheers.
MikesMovies
Hi Brian, thanks for the file, sadly when I ran it I got a message saying the version could not be determined and it made no changes.BrianCee wrote:When we had a previous user with the same problem Corel provided a "one off" fix - only problem is it was for X9 - but it may be worth a try on your system
Hmm also got this when I tried to run the service pack for x8.
Not looking good
Mike
MikesMovies
Not a happy easter bunny
Hi Mike
You could try installing Corel VideoStudio X8.5 Hotfix 2 again.
http://forum.corel.com/EN/viewtopic.php?f=1&t=58892
Did you try resetting the program by re-naming the 18.0 folder?
MikesMovies
Cool Trevor
Re-running the hotfix solved the issue.
Now all I need to know is how to get all my libraries back.
I keep regular full system backups, does anyone know where the files are that can restore my projects etc?
Great tip, thanks.
Great tip, thanks.
All of your files are where they were - stored on your hard drive
All of your projects are where they always were - opening a .vsp file should restore every thing to your timeline
only the libraries may have been emptied - but that is not your files - only thumbnails .
Not sure where your personalised libraries are - buried in a .dat file some where
MikesMovies
OK Brian, I could I guess risk recovering all the data files in app data but that might make things worse.
I had about 6 projects that had been complied, all these are wiped out and all I have left are Samples and Triple Scoop music
Well you could open those projects and then just drag and drop from the timeline into blank media file libraries to re-populate them
Hi Mike
Your Project files the VSP’s should still be on your pc and as Brian says should / can be used again. Deleting the library will not affect the projects.
Where did you save the VSP files, do a search of your pc.
If you have backed up this folder you should be able to replace the folder.
Please first make a copy of the original by re-naming to 15.0_old.
C:\Users\User name\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro\15.0
The folder is hidden by the operating system.
Add %Appdata% to the start search box to locate “roaming” folder
That should re-instate the old workstation and libraries as backed up.
MikesMovies
Might try that after todays work stream! Cheers
