Hi Trevorlata wrote:Hello
Carroll
As you are intending to burn a DVD then you have to create a Mpeg2 video file.
Can you confirm that if you view the Project Properties (Alt+Enter) show similar to these,
Microsoft AVI files
24 bits, 720 x 480, 4:3, 29.97 fps
Lower Field First
DV Video Encoder -- type 1
PCM, 48.000 kHz, 16 Bit, Stereo
After completing the project you should convert / render the project to a single video file, which has to be Mpeg2 as below
Share – Mpeg2
You will have to create your own profile using the Add + option to set these details.
The data rate of 8000kbps is suitable for video up to 70 minutes
How long is your project?
MPEG files
24 bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 4:3
Audio data rate: 384 kbps
If that renders without problems then use the new video (mpeg2) to burn a disc.
Yes DVD. My video is 19 min and change. And I had changed it to video encoder type 1 from the 2 which is the default, I assume. I don't see the Add + option anywhere. The white text throughout VS is at best 25 -50% white. It's very hard to see at times, but, I'm sure that Add + isn't on the page.
Microsoft AVI files
Lower Field First
This is the properties now in the share window for mpg-2
The Profile reads as "MPEG-2 (720 x 480, 4.3 60i, 8Mbps)" There is also another 4.3 profile in the drop down that has 30i instead of 60i.
MPEG files
Frame-based
(DVD-NTSC), 4:3
Carroll
