"Animating" jpegs
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
"Animating" jpegs
Post by Ken Veal »
Have some jpegs taken in quick succession therefore showing slight differences in the images.I want to show them displaying these changes in rapid succession and then repeat the sequence, possibly more than once.What is the best way to do this.
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: "Animating" jpegs
Post by RobertOZ »
The way I would do this is to highlight the range you want, then right click,select "Change Duration" then set the duration by frames NOT H./M./S. start at 10 frames then when you have the speed the way you want it, click OK,
zaphodikus
motherboard: ROG-X570-F-Asus
processor: AMD 3950 - 16 core
ram: 64Gb
Video Card: AMD RX 6700
Hard_Drive_Capacity: M2 1TB
Monitor/Display Make & Model: 4K BenQ
Corel programs: VS 2023 Ultimate, Painter 2020
Post by zaphodikus »
Ken if you are talking about a timelapse, you can right-click on the timeline and get a option to import images for timelapse. As Rob suggested, settings of anything around 7 up to 10 frames per photo work - but this feature only works if your camera sequentially named the pictures. Corel is pretty smart in working out the order so photos off any camera I have used (which is a limited experience) will work.
If you want to repeat the sequence, it works best to render the sequece out and then work with the movie file, so that you can apply effects like reversing much more easily.
