What do I need to do to get them all to show so that they can be used?
plugins not visible
Martin5000
- motherboard: Gateway TBGM01
- processor: 2.67 gigahertz Intel Core i7 920
- ram: 12280 MB
- Video Card: GeForce GTX 750
- Hard_Drive_Capacity: 984.47 GB
- Monitor/Display Make & Model: Hanns.G iH282
- Corel programs: AfterShot Pro3
plugins not visible
Hi, new to AfterShot Pro 2 v2.4.0.119 64bit. Figured to jump right in and install a few plugins that appear to be just what I need. Downloaded zPerspector_WL and mdRedEyes. In AfterShot, from the File menu, I selected Install Plugin ... browsed to the download location and selected each in turn. The displayed message said they were installed but in the right panel, under "Plugins 1" they don't appear, nor in any of the other areas. I also added asPluginManager-1.1.0-WLM in case that might help but even that doesn't show. If I install them again, the message says they are already installed so they are in there somewhere.
Hobgoblin
- System_Drive: N/A
Re: plugins not visible
Check that you have downloaded the correct version of the Plugin.
You must install 64Bit versions of the Plugin for AfterShot/AfterShot Pro 2.2 64Bit.
NB there is no 64Bit version of MDRedeyes!
Martin5000
- ram: 12280 MB
That was too easy
Considering I work with computers all day, how did I not see that? For some reason, I thought that a 64 bit program would be able to use 32 bit parts and not the other way around.
Thanks for pointing me in the right direction.
Hobgoblin
- System_Drive: N/A
You are welcome!Martin5000 wrote:That was too easyConsidering I work with computers all day, how did I not see that? For some reason, I thought that a 64 bit program would be able to use 32 bit parts and not the other way around.
We all been there at one time or another.
