adding a photo backdrop to videos
Re: adding a photo backdrop to videos
Post by BrianCee »
you should be able to do exactly the same wit a video of the train using a coloured background and the Chroma Key function in Videostudio
MikesMovies
motherboard: Gigabyte Technology Co ltd H81M-DS2V SOCKET 0
processor: Intel Core i5 4460
Video Card: NVIDIA GeForce GTX 1050
sound_card: NVIDIA Virtual Audio Device
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: PHL 242B1
Corel programs: Video studio X10 and PaintShop Pr
Post by MikesMovies »
Hi, I am sure I am being dim, but where do i find the similarity setting please?
This is the chroma effect I have.
Kind regards from Mike in Sussex UK
https://www.youtube.com/user/mikesndbs
Post by BrianCee »
AH - - you seem to be using New Blue - we were using the Videostudio Options Chroma key
I find it here
Hi Mike
There is a Chroma Key option below the library.
Place Image in top track
Place the Train on the overlay track, Fit to screen
Double click the clip to open the Options panel, choose the Attributes tab
Choose Mask & Chroma Key
Apply Overlay
Use Colour picker to select background,
Similarity to 20% ish, try different levels.
MikesMovies
Thanks, will post some results later as I am under orders just now lol
Post by BrianCee »
Just one further point
when you put your image in the top track double click it to open the options panel - then open the "Attributes" tab and click to tick the box against "Distort clip"
do not distort but hover your mouse cursor over the preview window and it will become a 4 way arrow - left click and push up so that much of the sky in the image is up off the screen and you can see the buildings without distortion
Well I have just tried the FX Chroma Filter and I cannot get it to work, must be doing some thing wrong?
The Mask and Chroma Key should work well
MikesMovies
Hi guys
Here is my first go using the above advice and just selecting the wall colour as the key.
https://youtu.be/LI6H-MmpOEo
It's getting there but as you see much distortion.
Thanks for the on going help :)
Mike
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
That result is very much expected as there isn't any unique color in your wall.
If you want much better results you better use a colored backdrop there.
Panasonic X900m, VXF1
Post by BrianCee »
Yes you are getting there but those problems are due to the background colour not being clearly defined giving you problems with the similarity setting
if you had a plain clear coloured background - that is any colour which is not present in the trains - all those problems would disappear.
MikesMovies
My green screen is a very bright green (proper green screen) I shall try and make a short test with that later and let you see it.
None of the trains have a bright green shade in them so hope will be ok.
Right, I am in trouble now so must go hahahah
Terfyn
motherboard: ASUSTeK P8H61-MX
processor: Intel Corei5-2320
ram: 8Gb
Video Card: NVIDIA GeForce 210
sound_card: NVIDIA High Def Audio
Hard_Drive_Capacity: 1000 Gb
Monitor/Display Make & Model: Acer & LG
Corel programs: VS X10 and PSP X8
Post by Terfyn »
A well defined monochrome should stop the "bleed through" on the carriages and trucks. Plus try to keep the camera position solid - I presume you are using a tripod.
I wonder if orange would be better, I cannot see any orange on the train setup. Chroma key does rely on something it can lock on to and this can be very difficult at times, even the TV companies get it wrong sometimes. Experiment and it should become good.
MikesMovies
You mean make the whole thing black & white? monochrome? Orange might work!
Terfyn
ram: 8Gb
Post by Terfyn »
MikesMovies wrote:You mean make the whole thing black & white? monochrome? Orange might work!
Not exactly, monochrome defines a single colour. If you already have a green screen, you could try it and select different colour rolling stock and engine.
MikesMovies
OK Orange screen test set up in end frame https://youtu.be/6gBsZrUJfiI good on the all green train but the yellow on the diesel is bad
