Program doesn't fit screen!
coralian65
motherboard: Samsung 700Z4A
processor: Intel Core i5-2430M
ram: 6gb
Video Card: Intel HD Graphics 3000
sound_card: Realtex
Hard_Drive_Capacity: 750gb
Monitor/Display Make & Model: Samsung N700Z4A laptop + HP w2207h external
Corel programs: AfterShot Pro2
Post by coralian65 »
I'm using ASP 2 - latest updates. I use a Samsung series 7 laptop and for a while now when I've attached my HP w2207H monitor, the program 'stretches' so that the right hand panel is half hidden, as are the max/min/close icons top right. As soon as I disconnect the monitor the display corrects itself. Until today, when, even without the monitor attached, I can#t see the right-hand panel ot close btton etc top right. I'm bemused as this is the only program I have that behaves like this/ PaintShop Pro X8 is fine, along with everything else I run.
Has anyone else experienced this, and does anyone know how to fix it?
Any help appreciated!
coralian65
ram: 6gb
sound_card: Realtex
Re: Program doesn't fit screen!
I eventually worked out what was happening! Attaching the external monitor via the laptop HDMI port was throwing ASP into a sort of off-centre full screen mode. I'd tried every other display setting on the laptop and then tried view modes in ASP. I rarely use Full Screen Preview. I turned preview off, then on then off again and it solved the problem.
Oddly, I also use a DisplayLink Pluggable Docking Station and this screen-size changing doesn't occur.. OK, I can get back to work again!
