Filters in PSP X8 and Windows 10
Cherie B
Corel programs: PSP9 PSP X8
Post by Cherie B »
I am having problems with getting a few filters to work in PSP X8 with ,Windows 10. Two that I have noticed so far are "Transparency...Remove White." It's funny but the "remove black" part of that filter works, but the "remove white" does not. The other filter that won't work is "AP01 Innovations." I have installed the 3 dll's in the appropriate folders, I think. All the other filters, so far are working fine. Why can't I get these to work? I have un-installed, restarted, re-installed. I have tried downloading from different sites to make sure all the info was there. Still....nothing. ? I have a 64 Bit system, but was told to use the 32 bit version of PSP. This did help with most of the filters, but not these two. Can anyone help? Thanks if you can, I [googlevideo][/googlevideo]would very much appreciate it.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: Filters in PSP X8 and Windows 10
Post by JoeB »
Cherie B wrote:I am having problems with getting a few filters to work in PSP X8 with ,Windows 10. Two that I have noticed so far are "Transparency...Remove White." It's funny but the "remove black" part of that filter works, but the "remove white" does not. The other filter that won't work is "AP01 Innovations." I have installed the 3 dll's in the appropriate folders, I think. All the other filters, so far are working fine. Why can't I get these to work? I have un-installed, restarted, re-installed. I have tried downloading from different sites to make sure all the info was there. Still....nothing. ? I have a 64 Bit system, but was told to use the 32 bit version of PSP. This did help with most of the filters, but not these two. Can anyone help? Thanks if you can, I [googlevideo][/googlevideo]would very much appreciate it.
Did they work with a previous operating system, like Windows 8? Did they work with a previous version of PSP with Windows 10? I know they work with PSPX7 and Windows 8.1.
JoeB
Using PSP 2019 64bit
karebai
processor: AMD DualCore A9-9410
Video Card: AMD R5
Hard_Drive_Capacity: 1TB
Corel programs: PSP7;PSPX;PSPX9;PSP2019 Ultimate
Post by karebai »
May or may not help ... I was instructed to put the dll files in the system32 and the syswow64 folders (also running 64bit, WIN10 and using 32bit PSP X8). My remove white & black work ....
JoeB
ram: 8 GB
Post by JoeB »
karebai wrote:May or may not help ... I was instructed to put the dll files in the system32 and the syswow64 folders (also running 64bit, WIN10 and using 32bit PSP X8). My remove white & black work ....
Yes, that's where the dll files should go.
JoeB
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Cherie B wrote:I am having problems with getting a few filters to work in PSP X8 with ,Windows 10. Two that I have noticed so far are "Transparency...Remove White." It's funny but the "remove black" part of that filter works, but the "remove white" does not. The other filter that won't work is "AP01 Innovations." ... All the other filters, so far are working fine. Why can't I get these to work? I have un-installed, restarted, re-installed. I have tried downloading from different sites to make sure all the info was there.
I looked for these filters in my plug ins and installed scripts and could not locate them.
It would help if you could indicate what filter set you are using. Where did you download them from? Any links?
Otherwise it is impossible for others to test these on their systems to see if it is a PSP problem or a system problem and to check for fixes.
It's a bit like phoning a doctor and saying "I have a problem" and saying nothing else.
