Audio Scorefitter
pepegota
- motherboard: ASUS TUF Z390-Plus
- processor: Intel i9 - 9900k
- ram: 64 GB
- Video Card: GTX 1660 6GB
- sound_card: On board sound
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Ben Q, "21" LCD
- Corel programs: VS 2018, VS 2019, VS 2020
Audio Scorefitter
Audio Scorefitter was not working. I had installed VSX9 on an SSD external drive. I went to unstall the program from the SSD, but it would not uninstall'. The program still works after the uninstall attempt. I lost the uninstall selection in add/remove programs. Is there an uninstaller that I can get so that I can do a clean reinstall. Trying to reinstall VSx9 fails-no screen is presented.
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Re: Audio Scorefitter
I had similar problem when I tried to "hide" X9 but still uninstall it, as the cleanup file do not work on my 7-32 I had to recall a system image file from pre X8 days. Have you tried the cleanup?
Panasonic X900m, VXF1
No, I doubt that the Clean-up will work, Corel have not provided an official Cleanup tool.
I had a similar problem after terminating the installation before completion, I guess that’s my fault.
Although my program would not run.
I had to use Revo to remove most files, (force uninstall) then manually cleaned Register of other X9 entries till I was able to re-install.
I guess you could disconnect the drive, then try installing to C:Drive
If that works delete all X9 files on SDD
I would advise that you install to C:Drive, but you know I would say that.
No comment required
No comment required
pepegota
- ram: 64 GB
Using the following I was able to install VS X9, from disc, by inserting in the Windows 7 run/search box: H:\Corel\Corel VideoStudio X9\Setup\{EE80DAA0-0071-475C-A222-F1782888FC55}\SetupARP.exe /arp However, now it will not start error message: Another user is running Corel VideoStudio
on this computer. Please close other session of Corel VideoStudio before starting. I removed all registry entries relating to drive H:, but it still will not start.
Any ideas would be appreciated.
pepegota
- ram: 64 GB
Problem solved. I was able to uninstall VSX(9 Ultimate using method in above post. The KB312's were removed, but the problem persisted until I removed KB3140410. I then installed the Bonus pack and all is well again.
pepegota
- ram: 64 GB
FYI
If you get in a jam.
A neat way to start VSX9 without installer:
(C:\Program Files\Corel\Corel VideoStudio X9\Setup)\{EE80DAA0-0071-475C-A222-F1782888FC55}\SetupARP.exe /arp
------------Path to Setup-------------------.
