Working with Capture one 8
Diggedy
Hard_Drive_Capacity: Trimdon Gr
Post by Diggedy »
When I export Tiffs from Capture one for work in paint shop pro, the saved version loses all its vibrancy. Im exporting in AbodeRGB and the working colour space within paint shop pro is the same but it seems as though its converting it.
Any ideas whats going on?
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: Working with Capture one 8
Post by Jean-Luc »
When you display the EXIF values, do you see the chromatic setting ?
I observed that saving a file in PSP with ICC profile UNCHECKED, removes ALL infos (should not). This is another problem but could be related to the color management inside PSP.
Various messages on this WebBoard speak about colorimetric problems with PSP.
Diggedy
Post by Diggedy »
Exif values in capture one of psp?
I may ask silly questions here, I understand whats going on ive just never had to look into it as usually programs just work well.
Jean-Luc
Post by Jean-Luc »
You may verify if the AdobeRGB or sRGB is written inside the file so other programs may apply the correct settings.
In PSP Shift+I displays the image informations:
Diggedy
Post by Diggedy »
sorry its taken a while to reply.
This is the exif data in PSP. Im exporting as AdobeRGB from capture one
Jean-Luc
Post by Jean-Luc »
Diggedy wrote:When I export Tiffs from Capture one for work in paint shop pro, the saved version loses all its vibrancy. Im exporting in AbodeRGB and the working colour space within paint shop pro is the same but it seems as though its converting it.
OK. Now check if Color Management is checked (ON) in PSP. If checked, uncheck (OFF). See if colors displayed are better.
I don't know what you mean by "vibrancy". It is saturation or color cast or something else ... ?
Diggedy
Post by Diggedy »
it looks like the colours are dull, some of the skin colours have gone pasty. Its almost like its gone back to the original RAW settings but has kept all the sharpening and exposure adjustments, just the contrast and saturation seems to have gone back to default
Jean-Luc
Post by Jean-Luc »
Diggedy wrote:it looks like the colours are dull, some of the skin colours have gone pasty. Its almost like its gone back to the original RAW settings but has kept all the sharpening and exposure adjustments, just the contrast and saturation seems to have gone back to default
You need to compare if image colors change if you load the same TIFF inside PSP with Color Management checked and with unchecked.
