PSP and Twain for scanner missing
bobtail
motherboard: Asus M5A97
processor: AMD FX 6350 6core
ram: 16gb
Hard_Drive_Capacity: 4tb
Monitor/Display Make & Model: Eizo 2243W
Corel programs: X8
Post by bobtail »
Since going to PSPX8 , when I click on the scan button it can't find the scanner. It found it in X7. Now it comes up with "No Scanner found", even though it is turned on and working vis Epson Scan.Any ideas ?
Joelle
ram: 16 GB RAM
Hard_Drive_Capacity: 1TB
Re: PSP and Twain for scanner missing
Post by Joelle »
Have you tried File>Import>From Scanner or Camera?
Works fine here.
Joëlle
Joëlle
(PSPX9 )
brucet
operating_system: Windows 8.1
Post by brucet »
You may have a conflict between 32 bit and 64 bit. Some scanners don't/wont work in 64 bit. If you have an older version of PSP in 32 bit try scanning from there, do a save and open the file in x8.
Regards
Zantara
processor: i5-2100 3 10 Ghz
ram: 12Gb DDR4
Video Card: Intel UHD graphics 620
Hard_Drive_Capacity: 256SSD 1TB
Corel programs: From PSPX2 to PSP2022
Post by Zantara »
I have the same problem since I installed PSP X8.
I only ever work with 32-bit versions, so it shouldn't be due to 64-bit conflicts.
Scanner worked fine in X7, but now it won't find the scanner either.
Tried removing x8 with the cleanup tool and then find the scanner with X7...no luck.
Have tried File > Import > From Scanner or Camera.
It's a bit like Servicepack 1 for X8...some have trouble, some don't.
Some work with Windows 7, some 8/8.1, some 10.
So the issue is somewhere with a file that came with other software?????
Thoris
motherboard: Gateway G33M05G1 MP
processor: 2.40 gigahertz Intel Core 2 Quad Q6600
ram: 6142 MB
Video Card: NVIDIA GeForce GT 430
sound_card: High Definition Audio Device SndTAudio
Hard_Drive_Capacity: 2129.94 GB
Monitor/Display Make & Model: ViewSonic VX2250WM-LED
Corel programs: PaintShop Pro Corel Paint
Post by Thoris »
I'm having the same issue in PSP X7, except it was working and now it is not. Does not recognize scanner, "Scanner Not Found". Even though it is clearly there in Control Panel and is available in other graphics packages. I am going to try a complete re-install of X7.
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: Iiyama 27"
Post by flagpole »
To the best of my knowledge TWAIN has only ever been 32bit and has now been deprecated in favour of WIA (Windows Image Accusation) which sucks.
lonestr37
motherboard: 64 BIT OPERATING SYSTEM
processor: AMD A8 5500 APU
ram: 8.00 gb
Video Card: 320 ghz
sound_card: IDT HIGH DEFINITION
Hard_Drive_Capacity: 1 t
Corel programs: COREL PAINT SHOP X8
Post by lonestr37 »
I been using PSP since it first came out years ago and I miss the old version. I was able to scan at a touch. I have a Windows 10 system computers now and have installed PSP X8 I can't get the scanner button to connect directly to scanner. When I have to scan I can only do so through file-import-from scanner or camera. This is really a task when you have to scan dozens of files. The Twain Acquire and Twain source do not work at all. Why have this feature of is not going to work. Can someone show me how to fix the problem? I read that the new x9 has the same issue and that has stopped me from buying one more upgrade.
JoeB
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Are you using the 32bit or 64 bit version of PSP? I' not sure Twain will work with 64 bit. And even then you should be sure you have the latest drivers installed for whatever scanner you're using.
If it matters, I'm on Windows 8.1, use PSPX7 32 bit (because I need to be able to access lots of 32 bit plugins) and Twain Source and Twain Acquire use the scanner software of my Canon MP280 and MX310 All-In-One printers.
JoeB
Using PSP 2019 64bit
rondo
processor: Intel I5 6600k 3.5 GHz
ram: 16 GB
Video Card: Nvidia 1060
sound_card: creative x-fi
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Asus ProArt
Corel programs: PSP X6, X9, Aftershot Pro 3, Painter
Post by rondo »
32 or 64 bit versions of PSP don't matter when calling up your scanner- it is a piece of hardware that has a driver that is 32 or 64 bit depending on the OS used, although the specific scanner model may have 32 bit software as most do.
In PSP X6 32 bit I get a list of my Twain Sources showing my Epson scanner and Import from Scanner brings up a small windows of my scanner's software window.
In PSP X6 64 bit I get a blank box for Twain Sources, but selecting Import from Scanner brings up my scanners software window.
This means that even though my scanner software is 32 bit, in PSP X6 64 bit it is running in it's own window- not like a plugin that requires 64 bit compatibility.
So even though in PSP X6 64 bit the Twain boxes are blank (unlike PSP X6 32 bit where all Twain devices are listed), Import from Scanner works.
So whatever version of 64 bit PSP you have, the scanner problems are a Corel code bug.
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
Don't mistake a scanner program for a twain driver.
Regards, Dan
FelixAtagong
Video Card: Nvidia GeForce GTX 1660 SUPER
sound_card: Realtek Nvidia High Definition Audio
Monitor/Display Make & Model: Samsung Syncmaster S27B350
Corel programs: PSP 2023
Post by FelixAtagong »
I have given up completely trying to scan in PSP9. It always freezes my computer;
So I scan in good old freeware IrfanView, save the result and then edit in PSP.
Grazie
motherboard: Asus TUF X299 MK 2
processor: Intel Core i9 10900X s2066
ram: 64gb
Video Card: EVGA RTX 3080 XC3 Ultra 10GB
Post by Grazie »
FelixAtagong wrote:So I scan in good old freeware IrfanView, save the result and then edit in PSP.
Wow! - Good Ole Irfan View. I didn't know it had that ability too. :wink:
Thanks Felix.
