Which downloaded X9 file(s) to use for setup and install
Glenn in Chile
motherboard: HP 83C8
processor: Intel Core i7-8550U CPU 1 80GHz
ram: 16 GB
Video Card: Intel UHD Graphics 620
sound_card: Realtek High Definition Audio sst
Hard_Drive_Capacity: 1000 GB
Monitor/Display Make & Model: Generic PnP Monitor |
Corel programs: VS Ultimate 2021
Post by Glenn in Chile »
Hi again, I downloaded the X9 ultimate version recently, opting for the 'download only' option (as opposed to 'Download and Install'). This gives me two folders ('64 bit' and 'Standard Content') as well as three application files ('VideoStudio', VideoStudioX9', and VideoStudioX9_Blu-ray'). In addition to these three application files, inside the two folders are other application files. My question is this: for my 64 bit pc, which of all these executable files should I choose to start my installation? And are there other executable files to follow the initial installation? Attached is a screenshot of the downloaded folders and files. Thanks.
screenshot of x9 folders and files downloaded
Screenshot 2016-03-02 12.43.08.png (11.09 KiB) Viewed 2292 times
Re: Which downloaded X9 file(s) to use for setup and install
Hi Glenn
You can install automatically by running the Video StudioX9 (Web Installer.)
You can select all packets or just the main, I would suggest installing all.
The installer will scan to check files then install the program
Once installed go to Preferences (F6) to set the TV System at bottom of window, that’s if you need Pal.
You can also manually install, first open the 64 bit folder and install the Ultimate pack by double clicking Setup.exe
Then install the Bonus Features followed by Standard Content, should not matter what order for the last two.
Glenn in Chile
ram: 16 GB
Great. Thanks. I'll do the Web Installer option. Much appreciated.
