Opening old VSP files in Ultimate X9
Graham Robson
Post by Graham Robson »
VS Ultimate X9 - won't open VSP files made in X8. Has anyone else had this problem?
Sorry! I should have said X6, not X8.
[Incidentally, X6 suddenly stopped loading - hence buying X9 . . . . any ideas on that one, as well?]
Re: Opening old VSP files in Ultimate X9
Post by BrianCee »
X6 stopped working due to a Windows update - there are many posts and topics in these forums about it and how to get round it
Why wont X9 open your .vsp files - what error does it give
Graham Robson
Problem solved. It was the trial X9 that I'd downloaded. Once I uninstalled everything and re-installed the official x9, there was no problem.
Thank you for taking the trouble to reply.
Graham
billyhorton
Post by billyhorton »
Hello everyone,
same problem here. VS Ultimate X9 does not open vsp projects created with X7.
It does not give any error. They just don't open, nothing happens, no clips are shown on the time line.
Both softwares run now fine on my computer (even X7 after the official patch due to the infamous windows update).
Anyone else with this problem.
Thank you.
Hi Billy
Welcome to the forums.
If you are using the Trial version then older VSP's will not open.
Only VSP's made with the trial can be used
cthoma51
Post by cthoma51 »
Hello - I recently purchased x9 VS - and cannot open vsp files that were created in VS x6. I installed x9 from the online site. Do you recommend I uninstall and reinstall x9? Not sure how to do that since I got it online. Thank you very much
Post by BrianCee »
I would not think we are ready to uninstall and re-install just yet
Do you still have the downloaded programme file - if yes then save it to a DVD or external drive along with the serial number so that it is safe for when you do want to re-install
if you deleted the download file (silly) and you had only just downloaded it then you may be able to download it again - links are usually available for a while - then save the download file - you never know when you will need it
what do the X6 project files consist of - just videos ? or something else which may not be compatible with X9 - Smartsound for instance - did you use that in X6 - it does not exist in X9
do you get any error messages at all
have you tried using "File >> open project" and browsing to the .vsp as well as RIGHT clicking on the .vsp and choosing 'open with >> Corel videostudio'
cthoma51
Post by cthoma51 »
Thank you for the suggestions, very much appreciated - here is the latest.
I tried opening the file by right mouse clicking and then choose open with CVSP, here is what happened:
- I received a "Load from Stream Error" - after OK 23 times the application crashed
- here are the crash details (this happened twice so far)
Problem signature:
Problem Event Name: APPCRASH
Application Name: vstudio.exe
Application Version: 19.1.0.12
Application Timestamp: 56c2acde
Fault Module Name: vstudio.exe
Fault Module Version: 19.1.0.12
Fault Module Timestamp: 56c2acde
Exception Code: c0000005
Exception Offset: 000000000017a869
OS Version: 6.1.7601.2.1.0.256.4
Locale ID: 1033
Additional Information 1: 58c4
Additional Information 2: 58c4ceb85680feffde4c3fc3595d850f
Additional Information 3: bd8f
Additional Information 4: bd8fbc9ec4772761647a4e387c907b27
BrianCee wrote: have you tried using "File >> open project" and browsing to the .vsp as well as RIGHT clicking on the .vsp and choosing 'open with >> Corel videostudio'
Please try opening the project from within Video Studio not via Windows Explorer
cthoma51
Post by cthoma51 »
When I try from VSP - it doesn't "do" anything. Its strange... it looks like it will open but the timeline does not get filled with content.
Hi cthoma51
The error report shows 19.1.0.12, that as far as I know is the trial version
The purchased download version will be 19.1.0.10 or 19.1.0.14 patched.
I would uninstall the program choosing to remove all personal settings.
Install from the purchased downloads.
Install either manually of via the Web-Installer (VideoStudioX9_Installer.exe)
Only project files created with the trial can be opened, it will not open files created with other versions of Video Studio.
