In the Help file, under "What is new in X8", I see :
• Gradient Preview - now you can view gradient updates on your
image as you make the changes in the Material Properties
I don't understand how to test this new feature.
Somebody knows ?
X8 Gradient preview
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
X8 Gradient preview
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: X8 Gradient preview
It's only for vectors. After adding a vector to the image select it with the pick tool. Then click the background swatch to open the materials dialog. Any changes you make to the gradient will show up on the vector. Including choosing new gradients.
This only works if a gradient is already set to the vector though. If you're changing over from a solid color to a gradient color, it won't show up until you accept the gradient first. After the gradient has been set the first time the live updating will work.
While happy to have it....the more I use it the more underwhelmed I am. But they've been getting into incremental improvements so it's possible the effect will be improved over time.
odyssee
- motherboard: ASUSTeK COMPUTER INC. B85M-G
- processor: Intel Core i5 4570
- ram: 8 go
- Video Card: Intel HD Graphics 4600
- sound_card: intel chipset
- Hard_Drive_Capacity: 1 To
- Monitor/Display Make & Model: samsung syncmaster913v
- Corel programs: paint shop pro X8 sp1
it would be nice if it worked with raster and mask layers too...
just the same way the color replacement tool does using plain colors
Jean-Luc
Tested with right-click first and the new feature doesn't work.LeviFiction wrote: Then click the background swatch to open the materials dialog.
Tested with left-click and it works !
Thank you !
odyssee
- ram: 8 go
works fine (although it only works on background)LeviFiction wrote:It's only for vectors. After adding a vector to the image select it with the pick tool. Then click the background swatch to open the materials dialog. Any changes you make to the gradient will show up on the vector. Including choosing new gradients.
thank you
trueblue
- Moderator
- motherboard: ASUS Z97M Plus
- ram: 12GB
Here's a tutorial on how to use this gradient with vectors. Vectors with Gradients
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
Creative-Designs
odyssee
- ram: 8 go
nice tuto, thank youtrueblue wrote:Here's a tutorial on how to use this gradient with vectors. Vectors with Gradients
