Display Settings
Stumann
- motherboard: asus motherboard
- processor: amd 3.4hz quad core
- ram: 2 gb
- Video Card: realtek
- sound_card: realtek
- Hard_Drive_Capacity: 1tb
- Monitor/Display Make & Model: acer h203h
Display Settings
I just recently upgraded to X8. I have an annoying difference in the way an image is displaying in "edit". It used to be that if I zoomed an image beyond the size if the window, the scroll bars for up/down, left/right would only go to the edge of the image. In X8 it is scrolling past the edge of the image. This is very annoying if I'm selecting a section using the freehand selection tool as it goes into "no man's land" if I'm not careful. Is there setting to limit this to just the size of the image?
trueblue
- Moderator
- motherboard: ASUS Z97M Plus
- ram: 12GB
Re: Display Settings
I'm not too sure what you mean because there's no change in X8 to previous versions. Have you set from Window how you want your documents to display, ie: tabbed, cascade?
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
Creative-Designs
Stumann
- ram: 2 gb
Maybe I'm not explaining myself correctly. If I zoom an image and I get it to where, lets say,only about 1/2 the image is in the edit window, then you get these scroll bars on the right (for up and down) and on the bottom (left and right). If you take the pan tool, or just use the scroll bars, it used to be that if you panned the image all the way to one side or the other, it would stop at the edge of the image. In X8, I can pan the image until it completely disappears from the edit window. This is very annoying if I'm editing something and I just want to use the mouse to move the image a little to reveal another section of the image. If I'm not careful, the image will disappear. Is there a way of limiting the movement of the image to only the size of the image? I don't see any purpose in having it move beyond the image. By the way, my previous version was X3, so maybe this has been an issue in versions in between.
- hartpaul
- ram: 8 Gb
Try Windows > and untick Tabbed documents
Stumann
- ram: 2 gb
That did the trick! Thank you.
