Trial useless - Is 4:2:2 supported?
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Trial useless - Is 4:2:2 supported?
Post by asik1 »
Panasonic X900m, VXF1
mxffiles
System_Drive: O
Post by mxffiles »
asik1 wrote:This is ver 7.0 I recived march.2015 to test.
38 Sec HD 7MB/s mts, took ~ 300sec to convert to H265 on AUTO settings.
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 18.0 MiB
Duration : 38s 302ms
Overall bit rate : 3 948 Kbps
Writing application : Lavf55.33.100
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4.0
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Duration : 38s 280ms
Bit rate : 3 687 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Interleaved fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.071
Stream size : 16.8 MiB (93%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration_LastFrame : -13ms
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 1.17 MiB (6%)
Last week I received 9.4
http://www.videoconverterfactory.com/hd ... converter/
mxf converter free download to convert HD camcorder files.
