Updated to SP3, everything seems working fine. The update was done online. Question: does in SP3 hotfix that resolves issues with running caused by update security for Windows 7 from Microsoft in February 2016 ? Or should it be installed separately ?lata wrote: CVSX8 64 bit version
1 / No problems using Fast Flick, can create then save and export back to VS timeline to continue editing
2 / No problems in using Variable Speed or Speed / Time lapse, not that I use those that often, but I don't have crashes.
3 / Not sure I understand that question, but I have no problems with Instant Projects either existing templates, creating new ones or downloading from Do-More
How to get rid of suggestions to upgrade to SP3 ?
AlexL03
- motherboard: ASUS P8H61
- processor: IntelCore i3 2120
- ram: 4 Gb
- Video Card: Radeon HD6670
- sound_card: built-in
- Hard_Drive_Capacity: 500 Gb
- Monitor/Display Make & Model: LG 1950B
- Corel programs: -
Re: How to get rid of suggestions to upgrade to SP3 ?
Hi Alex
When you install CVSX8 the program will not run, assuming the windows Updates have been installed.
We have to install the hot fix then the program will run
after a couple of starts the program will prompt to install SP3, download and install that.
View this post for further details
http://forum.corel.com/EN/viewtopic.php?f=1&t=58892
AlexL03
- ram: 4 Gb
- Corel programs: -
What are you talking about ? I have already installed SP3 ! Why do I need to install it again ?! I meant the patch which fixes an error after installing Windows updates КВ3126587 и КВ3126593.lata wrote:Hi Alex
Hi Alex
sorry for the confusion
Ok if you have to re-install CVSX8 for any reason
The program will not run till you install the Hot fix from http://www.videostudiopro.com/en/suppor ... sion-tab=1
(If the program runs immediately after installation then Windows Updates КВ3126587 и КВ3126593 have been uninstalled.)
You will now be able to start the program.
However the SP3 install option may only show after running the program 2 or 3 times / restarts
The program will then automatically give you the option to Download and install SP3, which you should do.
There are other Service Packs listed SP1 , SP2 but these are no longer required
At least that's how it works when I re-install the program.
