lens profiles
malepo
System_Drive: N/A
processor: Intel
Video Card: Nvidia
sound_card: Intel
Hard_Drive_Capacity: 690GB
Monitor/Display Make & Model: acer
Corel programs: AS1, AS2, PSPX8
lens profiles
Post by malepo »
Hi all,
yes I know there are other topics about lens profiles and there are how tos out there - but ...
this lens profile written to the profile_nikonSLR.txt for version 1.2.7 32bit is working pretty well
Code: Select all
begin lens
group: nikonSLR
multiplier: 1
aperture: 3.5
calibrate: true
menu_lens: Sigma 28-300mm f/3.5-6.3 DG Macro
cal_abc: 28.0 -0.008234 -0.009837 0.000000
cal_abc: 34.0 0.000517 -0.004678 0.000000
cal_abc: 55.0 -0.005159 0.005687 0.000000
cal_abc: 75.0 -0.004279 0.008223 0.000000
cal_abc: 100.0 0.001460 0.005137 0.000000
cal_abc: 135.0 -0.000965 0.006750 0.000000
cal_abc: 200.0 -0.003544 0.007188 0.000000
cal_abc: 300.0 -0.000008 0.004710 0.000000
end
having copied it to version 2.4 64bit leaves me with a "not calibrated"
I've put this calibration above in a my_profiles.txt and into the profile_nikonSLR.txt (into both, one of both) but all the same, nothing.
Any idea what else I could do?
Thanks & Cheers
Martin
malepo
System_Drive: N/A
processor: Intel
Video Card: Nvidia
sound_card: Intel
Re: lens profiles
Post by malepo »
ok - got it to work doing it the way like given here: http://forum.corel.com/EN/viewtopic.php?f=90&t=57724
in the end i deleted all lens files given by default, I only kept:
profile.txt
profile_genericSLR.txt
profile_nikonlenstable.txt
with profile.txt looking like this:
Code: Select all
version: 4.2
file: profile_nikonlenstable.txt
file: profile_genericSLR.txt
profile_genericSLR.txt only has definitions for those cameras and lenses I own - Example:
Code: Select all
#Nikon D600
begin camera
group: nikonSLR
group: genericSLR
multiplier: 1
menu_make: Nikon SLR
menu_model: D600
exif_make: NIKON CORPORATION
exif_model: NIKON D600
end
#Sigma DG 50-500mm F/4.5-6.3 APO HSM
begin lens
group: nikonSLR
multiplier: 1.0
aperture: 4.0
calibrated: true
menu_lens: Sigma 50-500mm f/4.0-6.3 APO DG HSM
cal_abc: 50 -0.0045257 0.0121475 -0.0118278
cal_abc: 72 -0.0004958 0.0119552 -0.0080606
cal_abc: 100 0.0055918 -0.0059002 0.0157995
cal_abc: 135 -0.0004780 0.0168021 -0.0111586
cal_abc: 195 -0.0013856 0.0198561 -0.0142491
cal_abc: 270 -0.0037291 0.0346552 -0.0361021
cal_abc: 320 -0.0295679 0.1122938 -0.1111381
cal_abc: 420 -0.0003765 0.0091695 0.0033635
cal_abc: 500 -0.0006307 0.0094386 0.0018172
end
my foundings were:
1. the "multiplier" value has to be the same like given in exif, in my case with a D600 those are all 1.0
2. the name of the lens at "menu_lens:" has to eqaul the lens name gien in exif or profile_nikonlenstable.txt
I'm not sure whether the "profile_nikonlenstable.txt" is needed but it looks like it isn't harming anything
profile_nikonlenstable.txt, this file I kept unchanged
an yes, you have to save those files and setting somewhere, as those will be overwritten with each update.
The positive thing about that solution for me is:
- I only have to deal with 3 files
- in AS the drop downs for lens corrections just list those cameras and lenses I really have
now I just need some the correction values for my Tokina 80-400 :) well looks like I have to take it to town and take some window shots.
Thansk an Cheers
Martin
PS. never mind for going to town with this one once again
Hobgoblin
operating_system: Linux
System_Drive: N/A
Re: lens profiles
Post by Hobgoblin »
Take the time to make a backup of your amended files - they will be overwritten and replaced when ever you do an upgrade or re-install. :cry:
Just Copy them back after upgrades.
