Cannot reduce to 256 colours
terrypin
motherboard: Asus Z170 Pro 4
processor: Intel Core i7 6700K 4.0GHz
ram: 32 GB
Video Card: None - uses built-in graphics
sound_card: HD onboard sound card
Hard_Drive_Capacity: 4.256 TB
Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
Post by terrypin »
One of my mapping applications (Memory Map) requires map images to be TIF with 256 or 16 colours, CMYK not RGB, to allow calibration. Until now I've had no trouble doing this from various maps, using Reduce Colour Depth, but I've now hit some sort of snag. I loaded a black and white map, or maybe including some grey. It was just a border around the UK, with dotted lines separating Wales and Scotland. Then I filled it with a light colour (used several, all with similar result). I reduced colour depth as usual. Checking showed it had 17 colours. But when I tried to save it, PSP8 displayed a message that because of the requirements it would be saved with 16 million.
What is going on here please?
Terry, East Grinstead, UK
Using PSP 8 & PSP 2018 under Win 10
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: Cannot reduce to 256 colours
Post by hartpaul »
Have just tested that with PSP 8 (not X8) and the message I get is "because of the limitations ... no EXIF information will be saved
terrypin
ram: 32 GB
Post by terrypin »
Thanks, appreciate the fast reply.
I get this:
Could you try it with my image please?
https://dl.dropboxusercontent.com/u/401 ... zzle-1.tif
And in case it helps, here's what I see in the TIF options:
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Have you tested different compression options to see if it still does the same?
terrypin
ram: 32 GB
Post by terrypin »
LeviFiction wrote:Have you tested different compression options to see if it still does the same?
No, as I'd seen that 'Packbits' option in previous successful saves.
But I think I may have been mistaken about the CMYK option. When I initially read the instructions "Scan or download the map image and save it as a 4 or 8 bit indexed color (16 or 256 color) TIFF or PNG format image. A full color RGB image cannot be used. The map should be free from distortion and discontinuities," I took that to mean it shouldn't be RGB. But now I think that was wrong and it should be RGB. Selecting that instead of CMYK gave no warning message. I'll try calibrating it asap to see if it's OK. Meanwhile, opening an earlier successful one (which I'd made in IrfanView), I see that has the RGB option selected, which reinforces my conclusion.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
I agree that you mis-interpreted the instructions. It doesn't seem as if you can save as CMYK color profile with a 16 or 256 indexed palette. Perhaps Google would be able to answer why not. :-)
JoeB
Using PSP 2019 64bit
