Animated GIF as overlay?
Cantisque
- motherboard: ASUS ROG Strix X570-E
- processor: Ryzen 9 5900X
- ram: 32GB
- Video Card: ASUS TUF RTX 3080Ti 12G
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: LG Ultragear 27gl850-b
- Corel programs: VideoStudio Ultimate 2021
As title asks, is there a way to insert an animated GIF (along with transparency) onto the timeline as an overlay track?
Re: Animated GIF as overlay?
I have never found a way of just relying on transparency for animated GIF's - if the areas you want transparent are fairly uniform in colour have you thought about just using Chroma Key
Cantisque
- ram: 32GB
That would work as well, as these are GIFs I make myself, but I can't actually find a way of adding them to the timeline. They just appear as static images that don't animated, at least in X8.
Strange - mine work fine
download and unzip the attachment and you should have a very short gif (5 frames) which works on my X8 - see if it works for you
Cantisque
- ram: 32GB
Thanks a lot Brian, I will give it a try later on and see what happens
Cantisque
- ram: 32GB
Hmm, still no luck.
I drag the GIF into the media library, then insert it onto the overlay track. It doesn't animate. Am I missing a step?
See if you can download and unzip the attachment and play the resultant video
Cantisque
- ram: 32GB
Yeah mine doesn't behave that way at all. Here's a video of what happens when I try.
http://expirebox.com/download/64bbd3338 ... a7500.html
(I couldn't attach it because 500kb limit)
So I see
Make sure you have Quicktime installed. Old Ulead software and now Corel require Quicktime to be installed to have animated gif support. Hope this helps.
Cantisque
- ram: 32GB
I tried re-installing both VS and Quicktime, unfortunately this did not help
