Video Studio Won't Open -- After Windows Update?
Re: Video Studio Won't Open -- After Windows Update?
I don't understand why you cannot see 4096 x 2160 options at 50p / 60p
Can you try this...........
Start a new project.
1 / if you add one of your 4096 x 2160 video files to the timeline, X9 should ask to match the project properties, view details, the right hand panel shows the video properties.
Works for most compatible video types, if it works...
2 / Go to Share - top left for Same as Project Properties
3 / Also from Share MPEG-4 view the profile list, are you saying 4096 x 2160 is not listed.
the image below is from a Pal installation so shows 50p, for ntsc should show 60p
click image for larger view
OGITH
processor: Seven
Hard_Drive_Capacity: 1TB
Corel programs: Corel VideoStudio X7
Post by OGITH »
Mine does NOT Have that' i Wonder why your Program has the 4096 & Mine Doesnt ???
& you Also Have 50 FPS Not 60...
Hi OGITH
50p is Pal standards whereas 60p is NTSC, the option can be changed via preferences ( F6) TV System.
I suppose you could try resetting the program by re-naming the 19.0 folder
That will create a new folder when launching the program.
How….
http://lata.me.uk/corel/reset/reset.htm
It will also reset the library so you may wish to export the library as a backup.
And if that does not improve things try a re-install.
I would do it manually rather than using the web installer via the 64bit\Ultimate folder, double click Set_up.exe
documentary
motherboard: ASUSs
processor: intel i7
ram: 4gb
Video Card: nvidia
Hard_Drive_Capacity: 750gb
Post by documentary »
hi !
Altough our below conversation and my full efforts to run the progamme , the result was not succesfull.
That's why , I uninstalled it and re-installed it again as a last option.
(of course the patches , as well)
It did work and I almost finished a new project with my Corel VS X8 Ultimate.
Today , I faced a very strange problem that when I click "SHARE" option no menü appears and a warning message says "encountered an improper argument" !!???
So , I tried to create a disc and using menü >Tools>Create disc>DVD , and I did it.
As I want to use "SHARE" menü and create a MP4 file as I did it several times before , how I can solve this problem ?
rgds,
lata wrote:Hi
I do not know what else to suggest.
If you have reset the program by re-naming the 18.0 folder and installed the Service Packs and Hotfix the next option is to try a re-installation.
The only other cause could be a virus or malware on your pc.
Do you have any software showing in Program and Features similar to Browser Protect, Browser conduit, Search Protect etc most will affect your pc function.
Is your PC upto date with all windows updates?
As I say not sure what else to suggest?
Can you please read this post and my reply, sorry if its not what you needed to hear, but a few recent posts, Do a search of the forum.
Maybe comparing installations may find the culprit.
http://forum.corel.com/EN/viewtopic.php ... 63#p328363
documentary
motherboard: ASUSs
processor: intel i7
ram: 4gb
Video Card: nvidia
lata wrote:Hi
I did reset the program to its factory default.
Firstly I exported the library , and then renamed the folder “18” as “18_copy”.
Later , I imported the library back.
It worked :)
Thanks and rgds,
saran
Corel programs: PSP X7
Post by saran »
I uninstalled the 2 updates listed, turned off automatic updates, rebooted my computer (windows 7) and Corel Videostudio X6 still won't open. I checked and those updates are not there anymore. HELP!!!!
Post by BrianCee »
saran wrote:I uninstalled the 2 updates listed, turned off automatic updates, rebooted my computer (windows 7) and Corel Videostudio X7 still won't open. I checked and those updates are not there anymore. HELP!!!!
why didn't you just apply the hotfix for X7 ?
View this post,
http://forum.corel.com/EN/viewtopic.php?f=1&t=58892
read CVSX7 details, download and install “Corel VideoStudio X7 Hotfix 1”
saran
Post by saran »
View this post,
Sorry . .I made a mistake when I typed it out. It's actually X6 not X7.
Post by BrianCee »
Then the solution to your problem is in this topic :- http://forum.corel.com/EN/viewtopic.php?f=1&t=59131
saran
Post by saran »
BrianCee wrote:Then the solution to your problem is in this topic :- http://forum.corel.com/EN/viewtopic.php?f=1&t=59131
That worked (once I figured out how to do it lol) thanks :)
earnolmartin
Post by earnolmartin »
My VideoStudio X4 still won't launch after running this batch script on Windows 7 x64 SP1:
Code: Select all
@echo off
REM
REM If VideoStudio fails to start it is because of two updates (below) Microsoft automatically
REM   installs and which is incompatible with VideoStudio
REM
REM See
REM   http://forum.corel.com/EN/viewtopic.php?f=1&t=58668
REM
REM The updates to uninstall are
REM KB3140410, KB3126587, KB3126593, and KB3134814
REM AND POSSIBLY:  KB3153171
echo Uninstalling KB3140410, KB3126587, KB3126593, and KB3134814 Windows Updates so that Corel VideoStudio X3-X7 will launch again in Windows 7...
echo.
wusa /uninstall /kb:3126587 /norestart
wusa /uninstall /kb:3126593 /norestart
wusa /uninstall /kb:3140410 /norestart
wusa /uninstall /kb:3134814 /norestart
wusa /uninstall /kb:3153171 /norestart
echo.
set /p shouldRestart="Problematic Windows Updates have been uninstalled. The computer needs to be restarted. Restart now? [y/n]: "
IF "%shouldRestart%" == "y" GOTO RESTARTCOMP
GOTO FINISHED
:RESTARTCOMP
shutdown /r /t 0
exit
:FINISHED
echo.
echo "Operations completed.  You'll need to restart your computer before changes take effect."
pause
So, what other KB updates cause this issue?
Post by BrianCee »
The solution to your problem may well be in this topic :- http://forum.corel.com/EN/viewtopic.php?f=1&t=59131
JaRo
motherboard: ASUS K556U
processor: Core i5
ram: 12 Go
Video Card: NVidia GEForce 940mx
sound_card: Realtek
Hard_Drive_Capacity: 1 TB
Corel programs: VS, Draw, PaintShop, Motion 3D
Re: Video Studio Won't Open -- After Windows Update? Sept 14
Post by JaRo »
After problem with GIF and SWF on my main computer following Windows Update Sept 14, 2016 (see http://forum.corel.com/EN/viewtopic.php?f=1&t=60296), I've had problem on my second computer.
This time, 16 updates for Windows 7 64 bit. VideoStudio Ultimate X4, X5 and X6 wouldn't start. I uninstalled KB3175024 and KB3172605. All three are now working and no problem with SWF.
VS Ultimate X4,X5,X6,X8. MotionStudio 3D, CorelDRAW X5, PHOTO-PAINT X5, PaintShop Pro X4
Lots of free stuff, explanatory documents : https://1drv.ms/f/s!AqzpHEzjQAwYkFiTJS6xeWPbPBsM
