Freezes on opening multiple files (Win 10, X8)
magnoliasouth
processor: Intel[R] Core[TM] i5-9300H CPU
ram: 8 GB
Video Card: Intel UHD Graphics 630
sound_card: Conexant SmartAudio HD
Hard_Drive_Capacity: 881 GB
Monitor/Display Make & Model: Generic PnP Monitor
Corel programs: PSP 2021, et al
Post by magnoliasouth »
The entire program (not system) freezes when I try to open more than one file. It doesn't matter if it's only 2 or 20. It freezes. Anyone else have this problem? Surely this would have been found in beta testing, so I can't believe it's an actual bug.
My system stuff is on my user info. No need to repeat it here.
ETA: PSP also crashes when it attempts to recover from the previous crash.
See profile data for system information.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: Freezes on opening multiple files (Win 10, X8)
Post by JoeB »
I'd have to say it's not a bug or everybody would be complaining about it. :-) Is this an issue you have had ever since you installed X8, or did it start some time after that? Do you have any previous version of PSP installed and, if so, does it have the same problem?
JoeB
Using PSP 2019 64bit
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Also open up your task manager and see if you can see what is using up your CPU.
You could also do a reset of PSP (start with Shift key held down). Save any work space customisations you may have.
JoeB
ram: 8 GB
Post by JoeB »
hartpaul wrote:Also open up your task manager and see if you can see what is using up your CPU.
Not only an excellent suggestion, but it also reminds me that sometimes PSP leaves a process running after it has been closed. Make sure that, before you start PSP again, you check with Task Manager to see if there is a Corel process running, even if it doesn't seem to be taking up much, if any, CPU resources. If so, end that task before opening PSP.
JoeB
magnoliasouth
ram: 8 GB
I failed to mention that I did that. Nothing is. Again, it's only when opening multiple files. As a reminder, it doesn't freeze up my system, only PSP.
