Upgrading from Aftershot 2 Standard to Aftershot Pro 2
Bugs & Suggestions
Ali71
processor: intel core i5
ram: 6gb
Hard_Drive_Capacity: 220gb
Post by Ali71 »
If you are Upgrading from Aftershop 2 Standard version (2.4.0.119 Jan 2016) to
Aftershop Pro 2 version, and not getting the Pro version, then serial number
you are adding is not overwriting the Standard version serial number, you have
to do the following:-
1. Locate your Aftershot Pro 2 Upgrade Serial Number and copy with Ctrl "C"
2. In windows 10 in the "Search the web and Windows" box enter :- "run"
3. click on Run Desktop App
4. type" regedit" in run box then click OK
5. Click Yes
6. Click expand at side of "HKEY_CURRENT_USER" and find "SOFTWARE" in the tree
7. Click the expand at side of "SOFTWARE" and find Corel in the tree
8. Click expand at side of "Corel" and find "AfterShot Pro v2" in the tree
9. Click expand at side of "AfterShot Pro v2" and find "Licence"
10. Click "license" and then right click keycode at top right of page
11. Select Modify, a box will open with your previous Serial Number highlighted
12. Paste your new serial number into this box with ctrl "v"
Check your serial number is correct before moving to next step
13. Once done click OK, close "Registry Editor" and open Aftershot Pro 2
14. The Aftershot pro 2 version should now open correctly.
