I use Ubuntu 15.10, 64bit version and 64bit aftershotpro2, every time I want to run it, it doesn't do anything. The problem is here from one of latest 2.3 versions.
AMD CPU, NVIDIA GPU
Output:
tomas@ubuntu-tom:/opt/AfterShot2(64-bit)/bin$ AfterShot2X64
Install Path: /opt/AfterShot2(64-bit)
LD_PATH: /opt/AfterShot2(64-bit)/lib:
XLIB_SKIP_ARGB_VISUALS: 1
I have SSE2
Bibble program arguments ("./AfterShotPro")
Loading plugins
AfterShot2 Pro New key used. 20
System locale: cs_CZ
AfterShot vers.: 2.4.0.119
Built on: "st led 13 2016"
Language: en
App Path: /opt/AfterShot2(64-bit)/bin/AfterShotPro
System Home: /opt/AfterShot2(64-bit)/supportfiles
User Home: /home/tomas/.AfterShot
Prefs Home: /home/tomas/.config/Corel/AfterShot Pro v2.conf
Platform: Linux
Issue: "Ubuntu 15.10 \n \l"
Kernel: "Linux version 4.2.0-25-generic (buildd@lcy01-02) (gcc version 5.2.1 20151010 (Ubuntu 5.2.1-22ubuntu2) ) #30-Ubuntu SMP Mon Jan 18 12:31:50 UTC 2016"
Build Mode: Release
Product Name: "AfterShot"
Registered Version
Initializing
Cpu Manager init: 6
**** Making CLManager
Neoprávněný přístup do paměti (SIGSEGV) (core dumped [obraz paměti uložen])
AftershotPro 2.4 doesnt'work in Ubuntu 15.10 - SIGSEGV
Re: AftershotPro 2.4 doesnt'work in Ubuntu 15.10 - SIGSEGV
Having the same issue with 2.* I am back to using 1.* which works fine
Linux Mint 17.3 (based on Ubuntu 15.10)
Which Nvidia driver are you using? I'm beginning to wonder if is isn't a driver conflict. I know that version 2.4 was working on my system
but, I don't know when it stopped. I'm using 362.18 nvidia driver, which is a recent update. I'm going to try and backup to an earlier
version and check it out.
greerd
- System_Drive: Z
- processor: Intel i7 920
- ram: 12 GiB
- Video Card: nVidia GeForce 260
- sound_card: Onboard
- Hard_Drive_Capacity: 5 TB
- Monitor/Display Make & Model: Dell UltraSharp U2410
I was getting the same issue, and your thoughts on Nvidia, Toolcrazy, pointed me in the right direction, also Darktable errored on startup with opencl errors. It seems to me that this problem started for me after updating Nvidia to 361.18. Note that Aftershot1 started up normally.
Googling lead me to my resolution, run Aftershot2 (or any software that depends on opencl (Darktable) as root (sudo /usr/bin/AfterShot2X64 %F) once. I can now start Aftershot2 or Darktable as normal user. Seem like something installed with root privileges during the Nvidia update and running as root seemed to resolve the issue.
Hope this will resolve your issues too!
That fixed it. I also notice that the directory in my home .Aftershot was all root owned. I had to change
owner and user to my user name to get things running.
Thanks again for the fix.
Well, the only way it will work, is if it is run via terminal with the commands above. If you run it
via the desktop icon, it keeps asking for the serial number and won't run. Back to the drawing board.
The config file permission were still set as root. Change the permissions to your username and everything works great. Up
and running like it is supposed to. Corel needs to fix the permission issues with the installer.
Tommy_CZ
- System_Drive: N/A
- motherboard: -----
- processor: AMD 6-core
- Video Card: NVIDIA+Intel
- sound_card: audigy Rx
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: sRGB calibrated
- Corel programs: AftershotPro 2
Corel needs to fix almost everything in Linux versions, it's a shame that Photoshop in WINE (!!!) crashes less frequently and is more reliable and faster (!!!) than this piece of .....
