Cleanup Tool or registry keys for X8 Trial?
holler02
processor: i5-6300HQ CPU 2.3GHz
ram: 12GB
Hard_Drive_Capacity: 1TB
Post by holler02 »
The X8 trial would not uninstall properly from my computer and now I cannot reinstall the trial or the full version (which I just paid for). I have deleted Corel files from program files and windows registry but I still get a warning stating that the program is already installed and it will not proceed with setup.exe. I suspect I am missing some non-obvious X8 registry files.
Re: Cleanup Tool or registry keys for X8 Trial?
Post by BrianCee »
Can't help with a clean-up tool specifically for the trial - you can try the one for the full version
down load and unzip the attached file and and then run the resulting .exe
if you want to continue searching the registry you should note that some parts of the programme are still listed as Ulead - so you might need to search for that as well
VSX8_Cleanup.zip
(635.74 KiB) Downloaded 255 times
holler02
ram: 12GB
Post by holler02 »
Thanks so much for the prompt response. I will try both.
holler02
ram: 12GB
Post by holler02 »
The cleanup tool worked. The full version is installing now. Many thanks.
