Warp Mesh Question
melissaconway
Warp Mesh Question
Post by melissaconway »
Is there a hotkey to constrain the vertical mesh lines? When I click/drag a node, I need the lines to stay absolutely vertical, and it's extremely difficult to see if the line is broken and adjust while dragging. Thanks.
Joelle
ram: 16 GB RAM
Hard_Drive_Capacity: 1TB
Re: Warp Mesh Question
Post by Joelle »
Hold the Shift key if you want to move a line
and hold the Ctrl Key of you want to bend a line.
Joëlle
Joëlle
(PSPX9 )
melissaconway
Joelle wrote:Hold the Shift key if you want to move a line
Joëlle
Thanks Joëlle, but Shift is supposed to move the entire row or column, while Ctrl is supposed to deform the row or column into a smooth curve. I want to constrain a node's line horizontally (keep it from bending at all) as I drag it. I've uploaded an example of what I mean.
(My bad, I wrote "vertically" in my original post, I suffer from directional dyslexia.) :roll:
melissaconway
Hold on, I figured out a way to do this. When I initially click on the node, I need to glance down at the bottom of the screen to where my cursor's x and y coordinates are displayed. As I drag to the right, I simply need to keep the y coordinate at the same number. Simple, but not intuitive. :D
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Post by Cassel »
If you use a guide, it can at least help you visually, even if the nodes won't snap to the guide.
Cassel
https://scrapbookcampus.com
