When searching for the EXIFtool and what it shows in RAW files of the RW2 format, I found the following parameters stored in EXIF:
[PanasonicRaw, PanasonicRaw, Image] 2 - Distortion Param 02: 0.010772705078125
[PanasonicRaw, PanasonicRaw, Image] 4 - Distortion Param 04: 0.02056884765625
[PanasonicRaw, PanasonicRaw, Image] 5 - Distortion Scale: 1
[PanasonicRaw, PanasonicRaw, Image] 7.1 - Distortion Correction: On
[PanasonicRaw, PanasonicRaw, Image] 8 - Distortion Param 08: 0.12359619140625
[PanasonicRaw, PanasonicRaw, Image] 9 - Distortion Param 09: 0.00579833984375
[PanasonicRaw, PanasonicRaw, Image] 11 - Distortion Param 11: -0.02374267578125
it originates from this URL: https://github.com/alchemy-fr/exiftool/ ... onic_4.out
Does someone know how this parameters apply to the lens correction parameters of ASP2. Namely the a,b,c values for the lens correction and "maybe" also for vignetting?
Obviously these informations are stored in the RAW based on this file that contains the equitation with a,b,c values http://www.homestyler.com/resource/exif ... onicRaw.pm:
# lens distortion information (ref 3)
# (distortion correction equation: Ru = scale*(Rd + a*Rd^3 + b*Rd^5 + c*Rd^7), ref 3)
%Image::ExifTool::PanasonicRaw::DistortionInfo = (
PROCESS_PROC => \&ProcessDistortionInfo,
WRITE_PROC => \&WriteDistortionInfo,
CHECK_PROC => \&Image::ExifTool::CheckBinaryData,
# (don't make this family 0 MakerNotes because we don't want it to be a deletable group)
GROUPS => { 0 => 'PanasonicRaw', 1 => 'PanasonicRaw', 2 => 'Image'},
WRITABLE => 1,
FORMAT => 'int16s',
FIRST_ENTRY => 0,
NOTES => 'Lens distortion correction information.',
# 0,1 - checksums
2 => {
Name => 'DistortionParam02',
ValueConv => '$val / 32768',
ValueConvInv => '$val * 32768',
# 3 - usually 0, but seen 0x026b when value 5 is non-zero
4 => {
Name => 'DistortionParam04',
5 => {
Name => 'DistortionScale',
ValueConv => '1 / (1 + $val/32768)',
ValueConvInv => '(1/$val - 1) * 32768',
# 6 - seen 0x0000-0x027f
7.1 => {
Name => 'DistortionCorrection',
Mask => 0x0f,
# (have seen the upper 4 bits set for GF5 and GX1, giving a value of -4095 - PH)
PrintConv => { 0 => 'Off', 1 => 'On' },
8 => {
Name => 'DistortionParam08',
9 => {
Name => 'DistortionParam09',
# 10 - seen 0xfc,0x0101,0x01f4,0x021d,0x0256
11 => {
Name => 'DistortionParam11',
12 => {
Name => 'DistortionN',
Unknown => 1,
# 13 - seen 0x0000,0x01f9-0x02b2
# 14,15 - checksums
Does someone know how to convert the values from RW2 EXIF into ASP2?
RAW EXIF and distortion parameters
bifer
- processor: i7-4720 HQ 2.60 GHz
- Video Card: NVIDIA GeForce GTX 960M + Intel HD4600
- Hard_Drive_Capacity: SSD 1+2TB
- Corel programs: ASP3, PSP2018 + VS2018 Ultimate
Re: RAW EXIF and distortion parameters
Just learned that maybe the formulas and coordination systems are different between different models. Adobe Camera Model vs. the hugin one of lensfun or maybe even a 3rd one used in the EXIF RAW's. Don't know. Still learning.
bifer
So my issue is solved: viewtopic.php?f=94&t=62061#p364563
