as mentioned here I opened a support ticket for my question http://forum.corel.com/EN/viewtopic.php ... 55#p319767
But maybe in the meantime it would be good to learn and understand how the support of a mentioned camera work when corel says it is supported: http://www.aftershotpro.com/en/products ... masp#tab=5
Am I correct when I understand it like this:
- if a camera in ASP 2 is supported for RAW it means you can open the RAW in ASP 2 and that's it, period?
- if a camera in ASP 2 is supported it doesn't mean there is automatically support for RAW correction included via the ASP 2 camera and lens DB?
- it also means ASP 2 has no camera profiles at all included, only some lens profiles in DB?
- ASP 2 cannot work at all with the RAW correction parameters provided by some cameras in the RAW EXIF, like some other competing tools can do?
Do I understand correctly that ASP2 in it's lens database, ...
... has only distortion correction
... doesn't have vignetting correction
... doesn't have chromatic aberration correction
Thanks for helping answer this questions.
ASP 2 RAW Support - how does it work?
jknights
- motherboard: Apple
- processor: Intel 3.08GHz Dual processor Quad Core
- ram: 24GB
- Video Card: ATI Radeon X1600
- sound_card: Intel HDA
- Hard_Drive_Capacity: 6TB
- Monitor/Display Make & Model: Apple Display
Re: ASP 2 RAW Support - how does it work?
I believe that this is a correct assumption.
Still learning after all these years!
