VideoStudio 9 chapters and indices not working
Charlie Howard
Post by Charlie Howard »
The chapters and direct positioning in a 2:03 hour DVD created with VideoStudio 9 did not work. The video plays fine, but attempts to skip around do not, and all 24 chapter buttons restart the video at frame 0.
The source material is 2 hrs, 3 minutes of AVI type-1 (three captured AVI files). The final video has a few simple transitions, one text block at the beginning, and no added sound track. It was created with the "fit and burn" option.
It rendered successfully (in 6 1/2 hours on an Athlon 1400), creating both a VIDEO_TS and an ISO image, which I then burned to a DVD. Both show the same incorrect behavior.
Shorter videos created by VS9 on this computer have worked flawlessly.
Can anyone suggest solutions to this? Thanks.
Others have been reporting problems with the fit-o-disk function, though I have to confess I haven't used it yet. Do you have the patience to perhaps reduce the bit rate of your file manually (and perhaps alter the audio settings?) so that it will fit on a single dayer disc? That way at least you could see whether or not the chapters baby has not been thrown out with the fit-to-disk bathwater... :lol:
Charlie Howard
Thanks, Ken; I'll try doing that and report the results tomorrow.
Last edited by Charlie Howard on Tue Aug 09, 2005 6:16 am, edited 1 time in total.
Charlie Howard
Setting the compression manually solved the problem, but it took two tries: the first compression level resulted in a video that was too close to the 4 GB limit of the Windows file system, and the last 5 minutes of the video were lost. Setting a lower compression, resulting in a 3.5 GB video, worked. The lower image quality is apparent.
There's probably a way around that 4 GB ceiling, but I don't know what it is. At any rate, everything's working now. Thank you, Ken.
