Installation Problem on Ubuntu 15.10 [solved]
Bugs & Suggestions
lundbech
operating_system: Linux
System_Drive: N/A
motherboard: HAL 9000
Post by lundbech »
After installing the latest version of AfterShotPro 64-bit (or any version that is 2.2.0.29 or later) I end up with this box, after the installation has finished apparently successful, and I try to run the program.
The dialogue does not respond in any other way than picking up an image of what ever content is above or below it.
In earlier versions (2.1.2.10 and before) the "folder locations" dialogue works as expected, and suggest ".AfterShotPro2" in my home directory. If I upgrade to a 2.2 or later version the same transparent "folder locations" dialogue appears. Maybe because AfterShotPro seems to be expecting the folder ".AfterShot" instead of ".AfterShotPro2".
I'm running this in Ubuntu 15.10. I've tested this in both Gnome and LXDE desktops.
Even if I uninstall the program, delete the settings folder it still on re-installation remembers my reg. info. Is there anyway to *completely* remove AfterShotPro from my system? Or is there another simple solution to this problem?
Hobgoblin
System_Drive: N/A
Re: Installation Problem on Ubuntu 15.10
Post by Hobgoblin »
You could try renaming the conf file in /home/~/.config/Corel/AfterShot Pro v2.conf
That contains the Registration and some path information.
lundbech
System_Drive: N/A
Post by lundbech »
Hobgoblin wrote:You could try renaming the conf file in /home/~/.config/Corel/AfterShot Pro v2.conf
Thank you very much. :)
There was a ".lock" file in that directory and deleting is actually solved the problem.
Hobgoblin
System_Drive: N/A
Post by Hobgoblin »
Good to know. 8)
