Paintshop pro X3 batch resize
purepanda
Post by purepanda »
Ok I got 1000's of images to resize I know how to batch resize what I need to know is how to batch it to resize the longest dimension to 500Pixels whilst keeping the aspect ratio
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Paintshop pro X3 batch resize
Post by LeviFiction »
With anything older than X8 you need to use a script to resize by the long side. This is because in older versions you have to manually calculate each side and the aspect ratio.
PSPX8 added a 'resize by side" option into its Resize dialog.
Here is a simple script that does what you want. The code is a bit messy as it comes from an experiment I was doing but it should work.
To change the length (in pixels) of the side just change the variable "LongSideSize" to whatever value you want. You can see in this code it's set to 500.
Just copy this code into notepad. Save it in your Scripts-Restricted folder with the extension "PSPScript" and it should work. Just execute this script in the batch process window.
Code: Select all
from JascApp import *
def ScriptProperties():
    return {
        # Change this to be your own information
        'Author': u'',
        'Copyright': u'',
        'Description': u'',
        'Host': u'Paint Shop Pro',
        'Host Version': u'8.00'
def Do(Environment):
    NewWidth = App.TargetDocument.Width
    NewHeight = App.TargetDocument.Height
    LongSideSize = 500
    result = App.Do(Environment, 'ReturnImageInfo')
    #Determine which side should be 500px
    if App.TargetDocument.Width > App.TargetDocument.Height:
        NewWidth = LongSideSize
    else:
        NewHeight = LongSideSize
    ImageResize(Environment, App.TargetDocument, Width = NewWidth, Height=NewHeight, Units = result['Unit'], Resolution = result['PixelsPerUnit'])
def ImageResize(Environment, Doc, Width=-1, Height= -1, AspectRatio =-1, MaintainAspectRatio = True, Resample = True, ResizeAllLayers = True, Resolution = 72, Units = "Pixels", Sharpness = 50):
    if Units == "Inches":
        Units = App.Constants.ResolutionUnits.PixelsPerIn
    else:
        Units = App.Constants.ResolutionUnits.PixelsPerCM
    if AspectRatio == -1:
        AspectRatio = Doc.Width / (Doc.Height *1.0)
    if Width == -1 and Height == 1:
        return
    else:
        if Width == -1:
            Width = Height * AspectRatio
        elif Height == -1:
            Height = Width / ApsectRatio
    App.Do( Environment, 'Resize', {
            'AspectRatio': AspectRatio,
            'CurrentDimensionUnits': App.Constants.UnitsOfMeasure.Pixels,
            'CurrentResolutionUnits': Units,
            'Height': Height,
            'MaintainAspectRatio': MaintainAspectRatio,
            'Resample': Resample,
            'ResampleType': App.Constants.ResampleType.Bicubic,
            'ResizeAllLayers': ResizeAllLayers,
            'Resolution': Resolution,
            'Width': Width,
            'SharpnessValue': Sharpness,
            'AdvancedMode': False,
            'GeneralSettings': {
                'ExecutionMode': App.Constants.ExecutionMode.Silent,
                'AutoActionMode': App.Constants.AutoActionMode.Match,
                'Version': ((8,0,0),1)
            }, Doc)
