DVD files to edit with Corel VideoStudio Pro X7
How do I get DVD files intoCorel VideoStudio Pro X7 to edit? The file extension is .VOB. It says file not supported.
juliart
Re: DVD files to edit with Corel VideoStudio Pro X7
If you already have the files on your computer then change the extension .vob to .mpg and they will then import - this will however result in your video being in blocks that you will need to render if you want one continuous file
if the files are still on the DVD then put the disc into your DVD slot on the PC and in Videostudio right click on the timeline and choose "Insert Digital Media" - when the new window opens click to tick the box next to the DVD drive - and also any sub boxes which may appear - the video will then import complete.
