Deformed menu's
Vera
motherboard: Acer Aspire TC-120
processor: AMD A8-7600 Radeon R7
Video Card: AMD Radeon R7 Graphics
sound_card: AMD High Definition Audio
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Acer H243H
Corel programs: Pantshop Pro X7 and X8
Deformed menu's
Post by Vera »
Goodmorning my name is Vera I am from Holland and I have been using PSP for about 18 years now.
I have a new computer with Windows 10 Pro and I use PSP X8 64bit.
My problem is I have a high resolution monitor and videocard with screen settings are 1920 x 1080.....now all things on the screen are so tiny I hardly can read, so I could change that in the configuration settings for a bit larger....from 100% to 125%....now I can see and read it a lot better....but when I use some things like a simple dropshadow or something else, my menu's are deformed and I can not acces all of it......does anyone have that too or any advise......will send some screen dumps.....thanks in advance......
Vera
screensetting
screensetting
deformed menu 2
deformed menu 2
deformed menu 1
deformed menu 1
rondo
motherboard: Gigabyte
processor: Intel I5 6600k 3.5 GHz
ram: 16 GB
Video Card: Nvidia 1060
sound_card: creative x-fi
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Asus ProArt
Corel programs: PSP X6, X9, Aftershot Pro 3, Painter
Re: Deformed menu's
Post by rondo »
I just installed PSP X6 on a 13" laptop with a 1980x1080 screen on Windows 7 and I have scaling set to 125% only with no changes for titles or anything else, and none of my menus are cut off or deformed like yours.
Scaling tool in Windows 7 was a bit simpler. Looking over what Windows 10 has, I would start over from the beginning of the set up for screen scaling and try some different options to see if you can resolve the issue. From your screenshot it appears you used the Advance Scaling option which may cause the problem- use the first option as show in my screenshot and see if it works better. Link to detail info about setting up scaling in Windows 10-https://www.thurrott.com/windows/window ... ay-scaling
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Re: Deformed menu's
Post by MarkZ »
PSP did not display tool interface windows correctly for many years, many versions if the user had set the display greater than 100%. These problems were fixed one at a time but as monitor resolution increased there were more and more complaints and finally, about PSP X7 or X8 the bulk of these problems seemed to be solved. I'm sure we will encounter instances were this is still a problem. But you should not be having the problems you describe with X8. My system is identical to yours and the display is correct.
In addition to Rondo's advice, all I can offer is that you try resetting the program; save your workspace and then restart PSP while holding the shift key. This solves a lot of problems of unknown origin.
Mark
